Home › Forums › Problems and solutions in GDL › Documentation elements, text handling › loop and richtext2
- This topic has 6 replies, 3 voices, and was last updated 6 years, 4 months ago by
Jože Marinko.
August 26, 2019 at 14:02 #18135
Jože Marinko
ParticipantHey,
I want read text from external .txt file. It is a data file, like Exel. So I have rows and columns. I read all data and put it in array variable.
Now I want read this data and put array fields in paragraph: Here is a code:
for i=1 to row
paragraph “CONTENT_PARAGRAPH_1” colAlign_1, 0, 0, 0, 1.0, 1.0
pen 1
set style “CONTENT_1”
content[i][1]
endparagraphtextblock “CONTENT_BLOCK_1” colWidth_1, 1, 0, 1.0, 1.0, 1, “CONTENT_PARAGRAPH_1″
richtext2 0,0,”CONTENT_BLOCK_1”
add2 colWidth_1,0
next i!—–
With content[1][1], 2D drawing is OK.
With content[i][1], I got a dot in floor plan and a message: String type expression required at line (with endparagraph).What is wrong?
August 26, 2019 at 16:54 #18136
KeymasterAre you sure that all of the elements in the array are strings? Are you sure row isn’t bigger than the size of the array?
August 27, 2019 at 10:35 #18137
Jože Marinko
ParticipantYes, I am sure. But I think there is not a problem in data but in index of array. If index is not variable [i] but number [1] everything is OK.
August 28, 2019 at 07:01 #18138
ParticipantI think the problem is you are creating the same Paragraph as you go throu the loop.
So when I=1, you are creating … paragraph “CONTENT_PARAGRAPH_1”
When I=2, you are creating … paragraph “CONTENT_PARAGRAPH_1”
When I=3, you are creating … paragraph “CONTENT_PARAGRAPH_1”All the same paragraph but with different content … content[i][1]
When you manually set ‘i’ to ‘1’ you now have the same content in the same paragraph, which is why it works.
August 28, 2019 at 07:15 #18139
KeymasterI tried Jože’s example with hard-coded content[][], and it was good with the repeating paragraph name.
The code working with content[1][1] and not with content[i][1] means the problem is after index [1][1].You can debug your data using
print contentbefore the loop.Péter Baksa
August 28, 2019 at 08:19 #18140
ParticipantI missed that the RICHTEXT and TEXTBLOCK commands were inside the loop as well.
I just tested and yes it does work – so the error must be in the data for the ‘content’ array.
August 29, 2019 at 07:13 #18141
Jože Marinko
ParticipantI finally find a mistake!
My variable for loop was to big. It must be row-1
I am sorry for interrupting you.
