LP XML Converter – change Main ID
Home Forums Problems and solutions in GDL Library build system LP XML Converter – change Main ID
This topic contains 3 replies, has 3 voices, and was last updated by  jan bacon 2 years, 8 months ago.
  • #3454
    Pavel Čapek
    Hello,
    I am looking for a way How to change Main ID via LP XML to avoid duplicated library (if I make copy of GDL object in XML file).
    Example of my process:
    1) develop an object in one language
    2) convert GDL to XML file
    3) copy XML file and translated them to different language (parameters description, localization string, object description and keywords)
    4) convert XML back to GDL
    5) open translated GDL and manually make “save as” for every object
    I want to make step 5) automatically, so Is there function for it in LP XML? Can you help me please with this?
    Thank you,
    Pavel
    Pavel Čapek
    BIM Project
  • #3455
    Hi Pavel,
    LP_XMLConverter does not have a function for that.
    I suggest to change the libparts’ Main ID during step 3. It is in the first lines of the xml, as MainGUID="0884EDB2-4B1B-4247-874E-36DB88381443"
    You can create new guids with many editors, or you can use online tools, for example:
    https://www.guidgenerator.com
    • #3456
      Pavel Čapek
      Hi Gergely,
      Thank you for quick answer. This solution also cross my mind, but I wanted to avoid it (no perticular reason). But It is probably only way for automatization of the process.
      Thank you again.
      Pavel
      Pavel Čapek
      BIM Project
  • #3555
    jan bacon
    Here’s a fun web generator for the interested: Guid Generator
