LP_​​XMLConverter – SIGINT opens GRAPHISOFT Bug Reporter
Home Forums Problems and solutions in GDL Library build system LP_​XMLConverter – SIGINT opens GRAPHISOFT Bug Reporter
    • #18290
      James Box
      Whenever I use ^C to interrupt an LP_XMLConverter command, the GRAPHISOFT Bug Reporter opens. This is frustrating because I have to wait for the Bug Reporter to allow me to hit “Quit”, which usually takes 1-2 seconds each time, then dismiss the “Do you still want to quit?” dialog (perhaps the second dialogue can be removed if the button text is changed to “Discard and Quit” or something similar). SIGINT needs to be handled differently since it’s not a crash.
    • #18322
      Please submit this description with the bug report if you haven’t already.
  • The forum ‘Library build system’ is closed to new topics and replies.
