Home › Forums › Problems and solutions in GDL › Object design › Macros and hotspot2
- This topic has 20 replies, 5 voices, and was last updated 7 years, 1 month ago by Laurits Frydenberg.
January 6, 2017 at 10:30 #2933Laurits FrydenbergParticipant
Hey guys
I’m trying make a 3D foundation element that has 152 difference types. So I decided to use the macro to reduce job to make them.When I use (call parameter all), it seems everything is fine.
But when I use (call parameter parameter1 = value, parameter2 = value, etc., Etc ..)
Then I have a problem with moving hotspot2. They come up in the right place and I can move them, but they only go back to square one without moving it I will adjust.
Is there anything that has an idea on what I can do with this.
PS! That’s fine if you make a little example when I did not then of very well on GDL
Thanks in advance
Laurits
Laurits Frydenberg
Technical drawing
January 9, 2017 at 16:33 #2934Gergely FehérKeymaster
Please attach a sample file (in zip). It should work, so we need to check your solution to find the problem.
January 9, 2017 at 17:33 #2935Laurits FrydenbergParticipant
Hello Gergely Fehér
YES there is a good idea. Here you ZIP files and I have sent a PDF file that tells a bit on I must deliver to my client. You see there that I have to adjust elment to corners and up the windows and doors. That is what is IMPORTANT for me to get to.
But friendly greeting
Laurits Frydenberg
Laurits Frydenberg
Technical drawing
January 10, 2017 at 16:31 #2937Gergely FehérKeymaster
If you give exact values to a macro (
call "macro" parameters B = 0.9
) then the macro will draw with this exact value… You should usecall "macro" parameters B = B
instead to be able to follow the changes of B parameter in your macro’s scripts.Gergely Fehér
January 10, 2017 at 16:41 #2938Laurits FrydenbergParticipant
Hello Gergely Fehér
Thank you very much this I will try to see if it helps me.
Thanks again
Laurits Frydenberg
Laurits Frydenberg
Technical drawing
January 11, 2017 at 10:16 #2939Laurits FrydenbergParticipant
Hello again Gergely Fehér
I try your suggestion, but when was length the same on the same on all four as I should have.
That I should have the length of 1200, 900, 600 and 450 mm and this is where I have to slightly adjust the lengths up door, windows and corners. Then it would have been easy to use hotspot to adjust the length.It’s possible I miss understood you. What I tried I was that I created two macros one that had parameters for the 1200 and the parameter 900.
The 1200 I used (call macro_navn parameter all) then works out everything as it should with hotspots.
But when I use when I use (call macro_navn parameter B = B, etc, etc, ..)
when the length the same as 1200 but I can use hotspots but it is wrong length.What am I doing wrong?
Thanks again
Laurits Frydenberg
Technical drawing
January 13, 2017 at 11:33 #2940Gergely FehérKeymaster
Sorry, I don’t understand what do you want to do. Please try to give a clear “requirement” for the functionality you need.
January 13, 2017 at 11:49 #2941Laurits FrydenbergParticipant
Hi
What I need is to get hotspot2 funke after I change size with call parameters with new values. So I can fine adjust these in plan.
I have four different sizes for these and they are 1200, 900, 600, 450 mm long.
Laurits Frydenberg
Technical drawing
January 16, 2017 at 10:28 #2942Laurits FrydenbergParticipant
Here I have created an image that explains what is my problem.
Laurits Frydenberg
Technical drawing
January 23, 2017 at 12:55 #2946Laurits FrydenbergParticipant
Hello
Is anyone have idea on how I can solve this problem this.
Laurits Frydenberg
Technical drawing
January 26, 2017 at 15:45 #2950Laurits FrydenbergParticipant
Hello Gergely Fehér
I wonder if you understand what I’m looking for I have not heard more from you.
Or do you need any more information from me?Laurits Frydenberg
Technical drawing
January 26, 2017 at 22:17 #2951Joachim SühloParticipant
Please check your Script, there is at least one script error at this line:
HOTSPOT2 ST +AA +TU +0.075 , 0, unID, STX, 1+128: unID=unID+1 !!!POINT BASE
You wrote STX where I have corected it to zero.
Now that hotspots maybe work correctly.GDL Object Developer
MAC OSx 10.14 -
January 27, 2017 at 10:52 #2952Laurits FrydenbergParticipant
Thanks Joachim Sühlo
I checked my script as you said, I try to set STX to zero. But that did not help either. As you see will become STX call parameter STX = -0.075 so when the item is also wrong when I want a 1200 element.
Have you or any other one idea on how I solve this problem.
Or whether it is possible to retrieve a GM file in its entirety into the file that I call element
Thanks
Laurits Frydenberg
Technical drawing
January 27, 2017 at 12:14 #2954Joachim SühloParticipant
I don’t understand why you set STX to -0.075 in the CALL. If STX has a fixed VALUE, you cannot change it by Hotspot. If you want to change STX by a Hotspot, you must set STX = STX.
MAC OSx 10.14 -
January 27, 2017 at 16:19 #2955Laurits FrydenbergParticipant
This worked but I thought that it was possible to put them out with a fixed value.
But it is not possible to lay them with a fixed value as the item is in the dimension I want to start with and then use hotspots to adjust it to a different value to the desired length.
If possible how I can do it?Laurits Frydenberg
Technical drawing
January 27, 2017 at 16:49 #2956Péter BaksaKeymaster
Hi!
I don’t know if I understand you correctly, but maybe what you need is setting the parameter value before the macro call. You can do that in the parameter script with the
PARAMETERS
command. I see 1200/900 setting depends onElement_type
parameter of your object, useGLOB_MODPAR_NAME
global variable to check whether last parameter modified was"Element_type"
, and if its new value is 2, setparameters B = 0.9
. Then you can call your macro in the 2D script usingPARAMETERS ALL
, the B parameter will be 0.9.Péter Baksa
January 27, 2017 at 17:16 #2957Laurits FrydenbergParticipant
Thanks Péter Baksa
How exactly put it into parameter script Peter
I’m sorry I’m new to using GLD so I feel a little sillyLaurits Frydenberg
Technical drawing
January 27, 2017 at 17:30 #2958Laurits FrydenbergParticipant
Many thanks everyone
After the last thing I got from Peter so it seems like I we shall doThanks thanks……
Laurits Frydenberg
Technical drawing
January 30, 2017 at 11:58 #2959Péter BaksaKeymaster
I recommend you to read this article:
The sections Changing the value of a parameter, and Connections between parameters can be used in your case.
GRAPHISOFT SE-
January 31, 2017 at 11:26 #2960Dominika BobályKeymaster
Moreso, you can try to use the VALUES command to set a discrete value-list for you parameter.
For example: “B” only should be working at 500, 200, 350, then:
values "B" 500, 200, 350
If you add a hotspot for “B” editing, it will jump to the previously set values only.Dominika Bobály
Product Manager
January 31, 2017 at 14:53 #2962Laurits FrydenbergParticipant
Hi all.
I can tell that my problems solved now.
The solution was to use:
if GLOB_MODPAR_NAME = "ELEMENT_TYPE" then if ELEMENT_TYPE = 2 then parameter B = 0.9, OS2 = 0.15, OS = 0.15, STX = -0.075, MKEN = 0225 endif
I want to thank everyone lots of good help 🙂
Laurits Frydenberg
Technical drawing
