Masking Edge Lines
Home Forums Problems and solutions in GDL 3D modelling Masking Edge Lines
    • #1887
      Masking
      Is there a rule of thumb, when PRISM_ s are hiding there edge lines when connecting with other PRISM_ s in the same object? In the image you can see, that sometimes there are edges visible and sometimes not. The arrows also show edges that are visible now, but disappeared in some cases (not reproduceable).
      As there seems to be no reliable rule, the best thing seems, to make the edges at connections invisible, to use the masking values of the PRISM_ command.
      MAC OSx 10.14
    • #1889
      You can try adding “body -1” commands between each prism_-s, and then if they have the same surface and they are in the same level they should be merged.
    • #1892
      Thank you, Gergely,
      that has solved the problem and saved me lots of hours of work 🙂
      MAC OSx 10.14
  • The forum ‘3D modelling’ is closed to new topics and replies.
