Home › Forums › Problems and solutions in GDL › Library migration › Migrating multiple objects forward into a single object
- This topic has 8 replies, 2 voices, and was last updated 9 years, 11 months ago by
Gergely Fehér.
October 12, 2015 at 18:57 #1714
David Larrew
ParticipantI am having trouble migrating multiple objects with different names and GUIDs into a single updated object with a completely different GUID.
Migrating a single object works fine, but when I add multiple GUIDs to the migration list it doesn’t want to work.
FYI – this is in AC16 (I’m trying to update older objects from AC6-AC12 to AC16)
Also I’ve experienced the same problem in AC18 for multiple objects from different versions with same name but different GUIDs migrating to one object of the same name.
Is there something I’m missing?
David Larrew, AIA
archiSOLUTIONS
www.archisolutions.com -
October 12, 2015 at 19:20 #1716
KeymasterHi, please attach sample objects – both the “old” ones and the “new”. There are so many thing that can go wrong in a migration, that I simply can’t help you without the samples.
October 12, 2015 at 19:58 #1720
David Larrew
Participant -
October 12, 2015 at 20:00 #1722
David Larrew
ParticipantSo, you can’t upload .GDL files? LOL… Let’s try this again.
David Larrew, AIA
archiSOLUTIONS
October 12, 2015 at 20:05 #1724
KeymasterUnfortunately only the standard image and document and zip files can be uploaded, no gsm and lcf from the forum. I’ll check your files soon.
October 12, 2015 at 20:23 #1725
KeymasterFor the first view: you shouldn’t comment the following lines:
! actualGUID = "29BC0A02-02ED-4536-A043-ECE303A3FB31"
Delete the exclamation mark, as you need to set your migration ID to the ID of your new object. In my quick test file, it solved the problem.Gergely Fehér
October 12, 2015 at 20:35 #1726
David Larrew
ParticipantI tried that before and it did not work. Maybe I’m testing it wrong…
1. I have placed all the old objects in a file with all the parts loaded.
2. I then delete the old parts from the Library.
3. I then reload the Library. And it says that the original parts are “missing”.Am I missing something?
David Larrew, AIA
archiSOLUTIONS
October 12, 2015 at 20:44 #1727
David Larrew
ParticipantHmmm. Looks like I have to actually close the file then re-open it for the migration to happen. Thanks for your help.
David Larrew, AIA
archiSOLUTIONS
October 12, 2015 at 20:52 #1728
KeymasterI think the easiest way to test forward migration is to have 2 ARCHICADs open at the same time: one with the old libraries and one with the new ones. Then I can simply place objects from the old library, and then copy-paste them to the other ARCHICAD with the newer libparts. If they are replaced during the paste, then forward migration is ok.
It’s quite fast, there are no problems with library reloading, and you can check visually the 2 different versions.Gergely Fehér
- The forum ‘Library migration’ is closed to new topics and replies.
