Home › Forums › Problems and solutions in GDL › Graphical editing › Migrating to AC20
- This topic has 10 replies, 3 voices, and was last updated 10 years, 2 months ago by
Laura Yanoviak.
July 11, 2016 at 16:40 #2609
Laura Yanoviak
ParticipantNot sure where to post this question, but the problem is affecting graphical editing:
I understand that there are now restrictions of Global Variables and Requests used in the Parameter Script (and Master Scripts used as a Parameter Script). The attached library part works fine in AC19, but the editable hotspots are all wonky in AC20.
Is this due to this new restriction, or some other migration issue? I just want a better understanding before starting to poke around all of my custom objects — thanks, LJY.
MacBook Pro 2.7 GHz Intel Core i7, 16 GB of RAM
AC17 US (5019) AC18 US (5100) AC19 US (3003) AC20 US (3012) on Mac OS X 10.10.3 -
July 11, 2016 at 16:43 #2610
KeymasterLaura,
please upload the file in .zip (.gsm is not allowed in this forum engine), or send it to the email address of GDLCenter. Thanks.Dominika Bobály
Product Manager
July 11, 2016 at 16:45 #2611
Laura Yanoviak
ParticipantYep — just noticed that — hereyago…
July 12, 2016 at 03:02 #2613
ParticipantLaura,
Do you mean that the arrow head moves when you stretch the text hotspot?
If so that is happening to me using your object in 18, 19 and 20 – they are all working the same.
I don’t see any problems with GLOB or REQUEST in the master/parameter scripts.
Those you have used are allowed (although judging from my other posts I am no expert in this field!).It seems to me the problem is with the 2D hotspots in that the one for the text position is altering the value for the arrow head.
I haven’t got time to dig into it in detail though just at the moment but hope this helps.Barry.
July 12, 2016 at 10:03 #2614
KeymasterA_ is used in the parameter script, which is GLOB_SCALE in old form. That may cause problems: its default value is set to 100 in paramscript, so your object works fine in 1:100, but starts to behave strangely in any other scale.
The warning is not “visible”, because you use the global in a valid condition, and this specific warning only works while interpreting the script (this was necessary because master script can use restricted globals in script-type dependent conditional expressions).Dominika Bobály
Product Manager
July 12, 2016 at 10:16 #2615
ParticipantA_ is used in the parameter script, which is GLOB_SCALE in old form.
Thanks for pointing this out – it is a good lesson.
I now must remember to search for the old form of GLOBALS when fixing up my library parts.
I might have missed this otherwise.Barry.
July 12, 2016 at 10:20 #2616
KeymasterTo have paper scale editable hotspots (which show mm in the tracker), you have to do the following:
- add a real type parameter to use as meter in GDL script (“paperSize_M”)
- add a real type parameter to use as millimeter for paper scale display (“paperSize_Mm”)
- connect the two parameters in parameter script (with GLOB_MODPAR_NAME, using a *1000 multiplier or divider)
- write an editable hotspot trio for the meter-substitute parameter in 2D, use the 1024 flag
- the hotspot’s
displayparamshould be the millimeter-representative - for the actual drawing, use a variable in 2D, which you calculate from the parameter “paperSize_Mm” using GLOB_SCALE (paperToModel in our scripts)
If you use the 1024 flag, the edited hotspot will be calculated by ARCHICAD to meters in paper space, according to GLOB_SCALE automatically, so you do not need to use GLOB_SCALE in parameter script to connect the model-size and paper-size parameter.
Check out the Multileader Label object in the official library, it has this functionality implemented.
The flag 1024 can be checked out here.Dominika Bobály
Product Manager
July 18, 2016 at 20:44 #2622
Laura Yanoviak
ParticipantAttached is the updated object. I replaced the A_ with GLOB_SCALE (good-to-know — I didn’t realize this could have adverse affects) and hid the base hotspot at the starting point of the leader (not sure why I had had it editable — I made this object for AC12 and haven’t used it in years).
My concern is: why does the “rubber band” follow the cursor in AC19 (on the left in the attached screenshot) but not in AC20 (on the right)?
July 18, 2016 at 20:45 #2624
Laura Yanoviak
ParticipantI thought it was attached…
AC17 US (5019) AC18 US (5100) AC19 US (3003) AC20 US (3012) on Mac OS X 10.10.3-
July 19, 2016 at 09:55 #2626
KeymasterLaura,
the problem is not that you used the old form of GLOB_SCALE in the paramscript, but that you used it at all. It’s still there, causing the “rubber band” to fall off in any other scale but 1:100 (that is the dummy default of this global in paramscript: it’s not containing an up-to-date value any more in AC20).
If I’m correct, you use the GLOB_SCALE to keep your object in paper size. You can do that without this global, see my post a bit further up (about editable hotspots for paper size). Sorry if I did not get your intention, but hopefully that will solve your problems with the object.Dominika Bobály
Product Manager
July 19, 2016 at 15:45 #2627
Laura Yanoviak
ParticipantOK — thank you — I understand now. It’s not clear to me how the 1024 flag works, but I will look into it and let you know if I have any questions.
This does affect quite a few of our custom Objects.
- The forum ‘Graphical editing’ is closed to new topics and replies.
