Home › Forums › General discussions › Missing Label commands in 22 GDL guide
- This topic has 6 replies, 4 voices, and was last updated 5 years, 6 months ago by Geoff Briggs.
July 10, 2018 at 08:45 #4175David ShorterParticipant
I guess I must be missing something but it seems that most of the label GDL commands are missing from the 22 GDL guide.
Or have I missed something -
July 10, 2018 at 09:50 #4176Barry KellyParticipant
It seems there are 22 label parameters in the 21 guide.
Only 5 in the 22 guide.
Anything to do with the fact that “LABEL_CUSTOM_ARROW” is considered deprecated since ARCHICAD 22?Barry.
July 10, 2018 at 10:17 #4177Dominika BobályKeymaster
Most of the label global variables are considered deprecated starting from AC22.
For the complete list of them, see here.
In the meantime, lots of fix named optional parameters have been introduced to continue the role of the deprecated globals:
– label specific ones are here
– text handling related general ones (for all annotation elements) here.So, the above is the reason why the updated GDL Reference Guide does not contain the same stuff as the previous one.
Hope this helps.Dominika Bobály
Product Manager
July 10, 2018 at 10:20 #4178Dominika BobályKeymaster
Also, we have a “new features guide” to give you some general overview of changes in ARCHICAD 22, see here, please.
Product Manager
July 10, 2018 at 10:59 #4179David ShorterParticipant
I have a Label which pulls parameters from door objects to define the Australian Egress Width correctly.
The Egress Width shown in Door 22 does not comply with Australian Standards.
My Label uses….
!!!!!!!!!!!!!!!!Pull standard parameters from standard doors
n = REQUEST (“ASSOCLP_PARVALUE”, “gs_rebate_width”, index, type, flags, dim1, dim2, framerebate)
nn = REQUEST (“ASSOCLP_PARVALUE”, “gs_ds_w”, index, type, flags, dim1, dim2, framerebate2)
m = REQUEST (“ASSOCLP_PARVALUE”, “ac_leaf_width”, index, type, flags, dim1, dim2, leafwidth)
o = REQUEST (“ASSOCLP_PARVALUE”, “gs_leaf_thk”, index, type, flags, dim1, dim2, leafthk)!!!!!!!!!!!!!!!!transfer to Label parameters
parameters rebate =max(framerebate,framerebate2)
parameters gs_leafwidth=leafwidth
parameters gs_leafthk=leafthkWhich works fine for the label (at the moment)but I cant schedule the result as I cannot transfer these parameters to properties.
Any ideas anyone? -
July 10, 2018 at 11:03 #4180David ShorterParticipant
“gs_rebate_width”
“gs_ds_w”
“ac_leaf_width”
“gs_leaf_thk”so basically I need to be able to link these door parameters to properties otherwise I cannot correctly define the egress width required for AUSTRALIAN doors
August 30, 2018 at 19:02 #4238Geoff BriggsParticipant
Related to the new text and label parameters, this Tip & Trick page needs to be updated:
It would also be great if a similar infographic could be created for the Pointer, Symbol Label, and Text Label settings panels. Thanks.
Geoff Briggs
DeForest Architects
Seattle, USA
