I have my MVO interface set to 600×600. For some reason the outfields just don’t appear when set as outside the standard size interface whereas infields work perfectly fine.
I’m using AC21. Is there any resolution to this?
Hello James,
second run of trying to post here, so in case you see a duplicate, that was me.
So, could you send us a sample of the problem? I failed to reproduce it with the latest official AC21 build. In case you do not want to upload here, write to the GDL Center email.
Thanks!
Library Developer, Library Team GRAPHISOFT SE
I worked it out! I was allowing the outfield to automatically pick up the width and height e.g ui_outfield “example”, 0, 0 which just doesn’t show up at all. What I needed to do was define the width and height of the outfield e.g ui_outfield “example”, 0, 0, 100, 19 which made it work. It’s a bit frustrating but now I know.
Author
The forum ‘Graphical UI and parameters list’ is closed to new topics and replies.
