New Label 19 with custom position of text and marker lines
Home Forums Problems and solutions in GDL Documentation elements, text handling New Label 19 with custom position of text and marker lines
This topic contains 2 replies, has 2 voices, and was last updated by  Olga Gregus 5 years, 1 month ago.
  • #1516
    When I create a new label in AC 19, it seems that the position of the content of the whole 2D-script is always relative to the end point of the label marker line in the 2D window, either if it is visible or not.
    Is it possible to create a custom position of the text content and custom marker lines?
    MAC OSx 10.12
  • #1519
    I found the anser: LABEL_POSITION[point][xy]
    and solved the problem.
    MAC OSx 10.12
    • #1537
      Olga Gregus
      Dear Sühlo,
      yes, you’ve found the right gdl global to solve the problem. This array contains the sizes of the label pointer, regardless of showing the pointer or not.
      Olga Gregus
The forum ‘Documentation elements, text handling’ is closed to new topics and replies.
