Parameters’s Dynamic Array
Home Forums Problems and solutions in GDL Graphical editing Parameters’s Dynamic Array
This topic contains 0 replies, has 0 voices, and was last updated by  HAI NGUYEN 4 weeks, 1 day ago.
  • #18876
    HAI NGUYEN
    Hi everyone,
    I need to create a dynamic array for angle parameters to assign to Graphical Editing Hotspot.
    As attachment image, I created an array for number of the rebars I need but when I moved hotspot, all of them is moved because I do not know how to create a dynamic array for “angle_2” parameter. I want to move each of the rebar separately.
    Please show me how to do it and write onto which script window for dynamic array parameters.
    P/S: When I can move each of rebar separately, then I want to know distance between selectd rebar’s hotspot to both of next rebars for confirm. I thought can calculate the distance of [i] to [i-1] and [i+1] elements. Then I will show them as displayParam in Graphical Editing Hotspot.
    	angle=0
    	for i=1 to iRebar_num-1
    		angle=i*360/iRebar_num
    		rot2 angle
    			hotspot2 0, 0, unID, angle_2, 6 : unID=unID+1
    			hotspot2 mRebarDis,0,unID,angle_2,4+128 : unID=unID+1
    			hotspot2 (mRebarDis*cos(angle_2)),(mRebarDis*sin(angle_2)),unID,angle_2,5 : unID=unID+1
    				add2	(mRebarDis*cos(angle_2)),(mRebarDis*sin(angle_2))
    					poly2_b	2, 1+2+4+64, gs_fill_pen, gs_back_pen,
    							0, 0, 901,
    							rKei/2, 360, 4001
    		del 2
    	next i
    Thank you so much.
    ___
