Point inside a polygon using Polygon Operations Macro
Home Forums Problems and solutions in GDL GDL add-ons Point inside a polygon using Polygon Operations Macro
This topic contains 3 replies, has 3 voices, and was last updated by  Simon PEYRARD 1 year, 7 months ago.
  • #2483
    Simon PEYRARD
    Hi !
    I try to display a grid of items in a custom polygon.
    I define a polygon with 3 hotspots, then I test a grid of points via the Polygon Operations Macro to know if the point is inside and I draw the item if it is inside.
    I often encounter strange results. Some points are considered on the contour of the polygon they are not …
    I did not find where the error or the bug, it happens only with specific value.
    I enclose a simplified version of the object with default values causing the problem …
    SimPey.
  • #2492
    Simon PEYRARD
    This forum does not seem very active but perhaps it lacked a question to my previous post …
    Did someone or object of the official library use this macro for this purpose? Have you ever noticed this bad behavior ? Is there a way around this problem?
    Thank you in advance,
    SimPey.
  • #2593
    Hi SimPey,
    The macro you are calling returns “On edge” status for points that lie on the line of the edge, even if they are outside the start-end segment. You could check in your code if that is the case.
    The official library doesn’t use this macro with the OPERATION_POINT_INSIDE_POLYGON parameter.
  • #2594
    Simon PEYRARD
    Hi Peter,
    Thank you for your answer, I was losing hope !
    You give me a good line of research, I had not noticed that the unwanted items were located on the extensions of segments.
    Unfortunately, my final object will not only have 3 segments, I do not know yet how to get out. Perhaps, I may do this by writing a function to determine if an item is on a segment.
    Thanks for your help !
    SimPey
