Polygon area
Home Forums General discussions Polygon area
This topic contains 3 replies, has 4 voices, and was last updated by  Nader Belal 4 months, 3 weeks ago.
  • #18494
    Jože Marinko
    I need to calculate area from polygon, which is defined with matrix points:
    x[i],y[i]…
    I found macro PolygonOperation, but result is wrong. In some cases smaller, in some cases even negative.
    My syntax is:
    for i=1 to segments
    put x[i],y[i]
    next i
    put x[1],y[1]
    call “PolygonOperations”,
    parameters opcode=6,
    srcPolygon1=2,
    result=1,
    returned_parameters _area
  • #18496
    Does it help if your polygon is regularized? Counterclockwise order of points, no self-intersection, no points on other edges.
    Currently we don’t have an universal solution for area calculation in the ARCHICAD Library.
    You can write your own code using the Shoelace formula.
  • #18591
    Harry Alex
    Blocked
    For any two basic polygons of equivalent territory, the Bolyai–Gerwien hypothesis declares that the first can be cut into polygonal pieces which can be reassembled to shape the subsequent polygon.
  • #18836
    Nader Belal
    @Harry Alex,
    The Shoelace formula is easier to implement.
    @Jože Marinko
    Note: For calculating area of close non-self intersection polygon, the vertices must go anti-clock wise, and for negative areas (holes) you must go clock wise.
    @Harru Alex,
    Can you implement Bolyai–Gerwien hypothesis in GDL ?
The forum ‘General discussions’ is closed to new topics and replies.
