Home › Forums › Problems and solutions in GDL › GDL add-ons › Polygon Operations Extension
- This topic has 7 replies, 3 voices, and was last updated 6 years, 2 months ago by
Pertti Pääsky.
December 11, 2015 at 15:14 #2025
Heimo Mooslechner
Participantthere is : https://gdl.graphisoft.com/gdl-docs/gdl-guide/chapter-12-miscellaneous/polygon-operations-extension/ her in this Site.
I would like to have some examples to look at – not just this documentation here – to shorten my learningcurve and to see the possibilities about it. I want to see, if it is possible tu use it for scripting without beeng a mathematal genius -smile..
Teacher in HTL-Salzburg
AC5-19, Win and Mac
GDL hobby developer -
December 13, 2015 at 21:10 #2032
Heimo Mooslechner
ParticipantWhat i am looking for exactly is this:
I have a given Array of x and y – a closed polygone in the form of:
x[points] and y[points] and the number of points in the Array in an extra integer named “points”.
I want to get a second polygone – with an inner offset to the original one.
As far as i understand the GDL-handbook, i first have to open a channel with the code:
kanal = INITADDONSCOPE ("PolyOperations ", "", "")
Then i have to prepare my source and Target – Polygones:
! --- QUELL- + ZIELCONTAINER ERZEUGEN PREPAREFUNCTION kanal, "CreateContainer", "Eingang", "" PREPAREFUNCTION kanal, "SetSourceContainer", "Eingang", "" PREPAREFUNCTION kanal, "CreateContainer", "Ergebnis", "" PREPAREFUNCTION kanal, "SetDestinationContainer", "Ergebnis", ""
after this, i have to give my extra stored coordinates into one array:
for oft = 1 to points arrayname[oft][1] = x[oft] arrayname[oft][2] = y[oft] arrayname[oft][3] = 0 !! angle? nZug=nZug+1 : zug[nZug]=oft next oft
Then i have to give the array to the function:
PREPAREFUNCTION kanal, "Store", "Polygon", points, 1, arrayname, zug (contourArray)
i have difficulties to understand this:
contourArray: An array which contains the index of the last vertex of the i-th contour. It must have exactly nContours items.
Therefor i would need an Example how to to this correctly!
Then i have to “init” the calculation with: ?? or how exactly?
dim resPolyIDArray[] nPgon = CALLFUNCTION (Kanal, "OffsetEdge", "Polygon", resPolyIDArray)
Then i have to read out the resulting array:
nPgon = CALLFUNCTION (Kanal, "GetDestinationPolygons", "", resPolyIDArray)
after this i can close it:
CLOSEADDONSCOPE (Kanal)
Then i can use put and get for an Poly2-Command to draw the polygone. Im i Right so far? There are a lot of possible mistakes i can make with this very complex command…
AC5-19, Win and Mac
December 13, 2015 at 21:23 #2033
Heimo Mooslechner
ParticipantI really would like to get an working GDL with only the functionality of the inner offset for a polygone!
AC5-19, Win and Mac
December 14, 2015 at 12:16 #2034
KeymasterThere are examples for the add-on in the Library Developer toolkit, and you can check the “Sill” and “Board” macros in the standard library for examples of using the addon. They are not about the offset function, but they shows how to use the contour array.
December 17, 2015 at 12:00 #2059
Heimo Mooslechner
ParticipantI opend the “Sill”-macro and tried to reverse-engeneer it but – real – “i am lost” with this.
It was much easier for me to write my own code for it to calculate the intersectionpoints:
“Innenversatz der Kontur”:
breite = -UEBERDAEMMUNGSBREITE
for k = 1 to points
!! Zuweisungen zu Segment
if k = 1 then !! 1. Segment – ergibt auch letzten Punkt
Winkelzuvor = alpha2D[points]
Winkeljetzt = alpha2D[k]
Winkeldanach = alpha2D[k+1]x1=x[points-1] !!!Koordinaten im Segment rauspicken
x2=x[k]y1=y[points-1]
y2=y[k]x11=x[k] !!!Koordinaten im Segment rauspicken
x21=x[k+1]y11=y[k]
y21=y[k+1]gosub “Parallele1”
gosub “Parallele2”
gosub “Schnittpunkte1”
gosub “Schnittpunkt zweier Linien – 2D”! addx xp[k]
! addy yp[k]
! circle 0.01
! del 2endif
if k # points and k#1 then !! zwischen- Segmente
Winkelzuvor = alpha2D[k-1]
Winkeldanach = alpha2D[1]x1=x[k-1] !!!Koordinaten im Segment rauspicken
x2=x[k]y1=y[k-1]
x21=x[k+1]y11=y[k]
gosub “Parallele2”
! addy yp[k]
! circle 0.01
! del 2endif
!! Ende zu Segmentnext k
!for k= 1 to points-1
! put xp[k]
! put yp[k]
!next k
!PRISM nsp/2, 0.01, !! Dummy-Prism für den späteren Wallniche-Befehl
!get(nsp)
!return !!! Ende “Innenversatz der Kontur”
“Parallele1”:
dx = x2 – x1 !!!x+y Distanz der Punkte des Segmentes
dy = y2 – y1if dx < 0 then dx = -dx
if abs(dx) < eps then dx=epsif dx < eps and dx < -eps then
Winkelsegment = 90
else
WinkelSegment = atn(dy/dx)
endifRewinSeg = WinkelSegment – 90
Diagonale1 = sqr (dx^2+dy^2) !!!!Distanz der Punkte des Segmentes
P1x1 = -breite * cos(RewinSeg)+x1
P1y1 = -breite * sin(RewinSeg)+y1
p1x2 = -breite * cos(RewinSeg)+x2
p1y2 = -breite * sin(RewinSeg)+y2if x2 < x1 then
P1y1 = breite * sin(RewinSeg)+y1
p1y2 = breite * sin(RewinSeg)+y2
else
endifreturn
“Parallele2”:
dx1 = x21 – x11 !!!x+y Distanz der Punkte des Segmentes
dy1 = y21 – y11if dx1 < 0 then dx1 = -dx1
if abs(dx1) < eps then dx1 = epsif dx1 < eps and dx1 < -eps then
Winkelsegment1 = 90
else
WinkelSegment1 = atn(dy1/dx1)
endifRewinSeg1 = WinkelSegment1 – 90
Diagonale2 = sqr (dx1^2+dy1^2) !!!!Distanz der Punkte des Segmentes
P2x1 = -breite * cos(RewinSeg1)+x11
P2y1 = -breite * sin(RewinSeg1)+y11
p2x2 = -breite * cos(RewinSeg1)+x21
p2y2 = -breite * sin(RewinSeg1)+y21if x21 < x11 then
P2y1 = breite * sin(RewinSeg1)+y11
p2y2 = breite * sin(RewinSeg1)+y21
else
endifreturn
“Schnittpunkte1”: !!!!Nicht von mir erfunden!
getValues = 1
put p1x1, p1y1, p1x2, p1y2, p2x1, p2y1, p2x2, p2y2
if not(parallelLines~5) thenspx = x~5
spy = y~5xp[k] = spx
yp[k] = spyelse
return
“Schnittpunkt zweier Linien – 2D”: !!!!Nicht von mir erfunden!
if getValues then
x11~5 = get(1): y11~5 = get(1)
x12~5 = get(1): y12~5 = get(1)
x21~5 = get(1): y21~5 = get(1)
x22~5 = get(1): y22~5 = get(1)
getValues = 0
u1x~5 = x12~5 – x11~5
u1y~5 = y12~5 – y11~5
u2x~5 = x22~5 – x21~5
u2y~5 = y22~5 – y21~5
!Prüfung ob parallel und Punkt finden
D~5 = u2x~5*u1y~5 – u1x~5*u2y~5
if abs(D~5) < eps then
parallelLines~5 = 1
else
parallelLines~5 = 0
endif!Schnittpunkt von nicht parallelen Linien:
t~5 = (u1x~5*(y21~5 – y11~5) – u1y~5*(x21~5 – x11~5))/D~5
x~5 = x21~5 + t~5*u2x~5
y~5 = y21~5 + t~5*u2y~5
elsexp[k] = P2x1!p1x2 !!!!!!!!!!!!nur die halbe Wahrheit – nur für genau waagrechte und senkrechte Polygone möglich!!!
yp[k] = P2y1!p2y2 !!! falls parallele waagrechte, dann nimm die Y und Y der vorigen Punkte
!!!!!! für iregndwelchen anders geneigten Parallelen muß es noch gerechnet werden!!endif
return
If someone needs it - feel free to use it. The central part is not from me - ist an internet-advice from a friend i dont know where he got it: So i cant tell about licence of this Code..
if getValues then
getValues = 0
parallelLines~5 = 1
else
parallelLines~5 = 0
AC5-19, Win and Mac
December 17, 2015 at 12:07 #2060
Heimo Mooslechner
ParticipantSorry about the formating-i made a mistake, but after three times of editing, ist not possible any more to change anything here.
AC5-19, Win and Mac
February 23, 2016 at 19:04 #2290
Pertti Pääsky
ParticipantHi Heimo
Here’s an object which opened the POE door for me, it is originally made by GS, I have only issued the offset-lines script.
As you know it is hard to understand how POE works.
Basicly you define the polygons, add information of contours and edges. Then you open the add on and perform operations. What you get is almost similar data as you put in. Of course it must be processed to get resulting polygons.
I think there was a bug in the script so that it works not in all situations, but maybe this helps a little.AC 19 Win 7 HP elitebook
February 23, 2016 at 19:07 #2291
Pertti Pääsky
Participant“Upload Errors:
1.PolyOperations_Example19.gsm: Sorry, this file type is not permitted for security reasons” !!!Maybe .zip is more safe?
- The forum ‘GDL add-ons’ is closed to new topics and replies.
