PRISM defined by user
Home Forums General discussions PRISM defined by user
This topic contains 1 reply, has 2 voices, and was last updated by  Péter Baksa 8 months, 3 weeks ago.
  • #4098
    Achilleas Pavlidis
    I’m new to gdl, and I’m trying to create an object that is basically a PRISM but with the number of edges defined by the user.
    Is this possible?
  • #4099
    short answer: yes.
    But you can’t do it like eg. the slab tool, where the user can draw a polygon. You have to add parameters to control the number of sides, and each vertex’s coordinates. Use editable hotspots on the vertices to let the user change them easily.
    Another possibility starting with AC21 is to use a profile parameter: the user can edit the profile in the profile editor as a drawing, and your object will change accordingly.
