Profiles shown in labels
This topic contains 1 reply, has 2 voices, and was last updated by  Péter Baksa 1 year, 7 months ago.
  • #4343
    Is it possible to create a label, that reads the Profile from its parent (Wall, Column, Beam).
    Yes, I can create one manually and see that the Profile Name is build in 2D from the Property GUID,
    e.g. “<PROPERTY-EAB6C4F7-A51F-4C13-BDBD-A72D4EFE9EC6>”.
    But is it also possible to use this value to show a 2D-Section of the profile in the placed label?
    Maybe this Autotext Style cannot be used in the script
    like any other Autotext as usual. But maybe there is anaother way?
    MAC OSx 10.12
  • #4344
    use parameters ac_wall_profile_name, ac_colu_profile_name, ac_beam_profile_name in the label to get the name of the composite or profile attribute.
    (You could also use the globals WALL_COMPS_NAME, COLU_PROFILE_NAME, BEAM_PROFILE_NAME. For walls WALL_COMPS_NAME returns the composite name too, so that can go wrong if there exists a profile and a composite with the same name.)
    Use that string with profile REQUESTs (“Profile_components”, “Profile_default_boundingbox”, “Profile_default_geometry”, “Profile_component_info”) to get the profile geometry, and draw what you’d like. You can only get the default profile geometry, profile offset modifiers currently aren’t accessible to GDL.
