Projection code
Home Forums Problems and solutions in GDL 3D modelling Projection code
This topic contains 2 replies, has 2 voices, and was last updated by  Jeroen de Bruin 4 years ago.
  • #2536
    Jeroen de Bruin
    Dear GDL Aficionados,
    I am using the Projection code with mask 3 (shaded). This produces a colored projection. However it also includes some shadow effects. Is there a combination where I can see the original Surface Color (RGB) in 2D?
    new Parameter: Surfaceblock
    2D Script:
    PROJECT2{3} 4,270,3+1024, 15
    ADD2 1,0
    PROJECT2{3} 3,90,3+1024, 15
    ADD2 0,.5
    PROJECT2{3} 5,90,3+1024, 15
    3D Script:
    MATERIAL Surfaceblock
    BLOCK 1,1,1
    ADDZ 1
    ADDX .4
    ADDY .4
    BLOCK .2,.2,.2
    Jeroen de Bruin
  • #2592
    Hi Jeroen,
    Yes, this is possible with some sort of hacking.
    You can pass parameters to the 3D script with PROJECT2{3}. Set up a parameter to signal that you want a special 3D model that is rotated to the same position as the top view. That way you can get equivalent shadings.
    Note those shadings won’t be the actual rgb of the surface, I don’t know of a way of achieving to display that.
    2D:
    PROJECT2{3} 3, 90, 3, 15, parameters side = 0
    PROJECT2{3} 3, 90, 3, 15, parameters side = 1
    PROJECT2{3} 3, 90, 3, 15, parameters side = 2
    3D:
    if side = 1 then rotx 90
    if side = 2 then roty -90
    BLOCK 1,1,1
    ADDZ 1
    ADDX .4
    ADDY .4
    BLOCK .2,.2,.2
  • #2602
    Jeroen de Bruin
    Thank, Péter,
    I was already using that work around, but that does not give the proper RGB of the Surface. Can you place this on the wishlist to have a projection without shadows?
    regards,
    Jeroen
    Jeroen de Bruin
