Quantity withdrawal
Home Forums Problems and solutions in GDL Object design Quantity withdrawal
This topic contains 2 replies, has 2 voices, and was last updated by  Gergely Fehér 3 years, 3 months ago.
  • #3167
    Laurits Frydenberg
    Hello everyone.
    Is there a way to get out volumes and square meters on the basis of filler or material when I have used CPRISM_ top_material, bottom_material, side_material.
    All help is received with thanksgiving.
    Laurits Frydenberg
    Technical drawing
  • #3179
    Laurits Frydenberg
    Is there no one who knows this ???
    Laurits Frydenberg
    Technical drawing
  • #3180
    If you want to schedule the total surface areas, then it should be done “outside GDL” – with the scheduling function of ARCHICAD. If you would like to use the old listing – use the property scripts.
    Please always describe the goals with as much details as possible – without that we can’t help…
