Radial opening sides with wallhole
Home Forums Problems and solutions in GDL Doors and windows Radial opening sides with wallhole
This topic contains 1 reply, has 2 voices, and was last updated by  Gergely Fehér 4 years, 7 months ago.
  • #1890
    On page 449 of the reference guide, we learn that the automatically-cut opening has radial sides, while if WALLHOLE is used the sides are parallel. Is there any way to get radial sides, in the case where WALLHOLE is needed because of a non-rectangular opening? I’m only concerned with 3D.
  • #1891
    You should try the wall niche instead – that can create pyramidal or wedge shaped cutting bodies – same as the cutform command.
    In some situations, you’ll need more than one cutting bodies to have the proper cut on each sides – especially with reveals. Many of the standard shapes are handled by the WallholeCut macro in ARCHICAD library, you can check that too.
