Remove edge of picture objects Home › Forums › Problems and solutions in GDL › Object design › Remove edge of picture objects Tagged: picture edges This topic has 2 replies, 2 voices, and was last updated 5 years, 3 months ago by Jaime Ingram. Viewing 2 reply threads Author Posts November 22, 2015 at 17:48 #1925 Jaime IngramParticipant Hello, I want to remove the visible edges on some trees that I am creating with alpha channeled picture objects. How can I remove the border edges around the leaves so that they do not show in the 3D window? Attachments:Screenshot.jpg November 23, 2015 at 09:23 #1927 vistasp mehtaParticipant James, is this in OpenGL? If so, you will have to turn off contours. If you want to render it correctly in Cine Render, you’ll have to use the Physical engine. Have a look at this thread on AC-Talk. http://archicad-talk.graphisoft.com/viewtopic.php?p=233352 = v i s t a s p = bT Square Peg http://archicadstuff.blogspot.com http://www.btsquarepeg.com | 18 INT | Win7 x64 | November 29, 2015 at 14:45 #1951 Jaime IngramParticipant Thanks for your answer, but what I’m after is to disable the edges only around the leaves, not in the rest of the object or the entire 3D window. Author Posts Viewing 2 reply threads The forum ‘Object design’ is closed to new topics and replies.
