Request Override Surfaces
Home Forums Problems and solutions in GDL Object design Request Override Surfaces
This topic contains 2 replies, has 2 voices, and was last updated by  Daniel Virtic 4 years, 3 months ago.
  • #2187
    Daniel Virtic
    Hello everyone, Is there a way to request the name of Overridden surface of an ArchiCad element, on each faces and edge.
  • #2204
    Csilla Mai
    Hi Daniel,
    The surface indices of the ARCHICAD elements are available through the Global Variables. To get the name of the material you can use the “Name_of_material” request. For example displaying the material names of a slab element in a label object in 2D:
    _matTop 	= ""
    _matBottom 	= ""
    _matEdge 	= ""
    r = request ("Name_of_material", SLAB_MAT_TOP, _matTop)
    r = request ("Name_of_material", SLAB_MAT_BOTT, _matBottom)
    r = request ("Name_of_material", SLAB_MAT_EDGE, _matEdge)
    text2 0, -1, _matTop
    text2 0, 0, _matBottom
    text2 0, 1, _matEdge
    Is this solution the one that you need? Could you please explain that what would you like to use the material names for?
    Csilla Mai
  • #2205
    Daniel Virtic
    Thank you Csilla.
    It’s working. I need to get the override surface of elements, in order to have them in the schedule via label tool. I create a custom label, where I need to round up some values, such as wall height, etc according to my needs.
