Requesting Parameters from another Object
Home Forums Problems and solutions in GDL Object design Requesting Parameters from another Object
This topic contains 2 replies, has 2 voices, and was last updated by  Kyle Boyd 4 years, 7 months ago.
  • #1813
    Kyle Boyd
    I am wondering if it is possible in 19 to request/reference parameters from other objects. (I am building some custom labels).
    Currently I can grab an object’s ID using GLOB_ID, or similar. But I would like to grab a specific parameter in the object say, randomPAR. Is this possible? If so, how?
    So far I have tried:
    I have a custom object with the parameter TestPAR defined in the Parameters as a text parameter. In my label object, I try
    re_parameter = REQUEST (“ASSOCLP_PARVALUE”, “TestPAR”, nameind_TEST, type_TEST, flag_TEST, dim1_TEST, dim2_TEST, val_TEST)
    labelText = val_TEST
    but it results in the error “Uninitialized variable
    at line 13 in the 2D script of file TEST LABEL.gsm.”
    I have also tried substituting “ac_bottomlevel” for “TestPAR” with similar results. Can someone help?
    *this is a duplicate to a post I made on Archicad-Talk, but I figured would post here as well.
    That post is here
    Also I have referenced this post from 2003 http://archicad-talk.graphisoft.com/viewtopic.php?t=648
  • #1814
    Initialize that val_TEST variable.
    val_TEST =""
    If you don’t initialize you will always get a warning. Sometimes it doesn’t matter, but with Requests it often does. If variables aren’t initialized, they are assumed to be numbers, and that variable needs to be a string.
  • #1815
    Kyle Boyd
    Awesome, thanks James!
    Now I know.
