Rotating editable hotspot
Home Forums Problems and solutions in GDL Graphical editing Rotating editable hotspot
This topic contains 2 replies, has 2 voices, and was last updated by  Geoff Briggs 3 years, 6 months ago.
  • #2038
    Geoff Briggs
    Hello,
    Please post an example of how to code an editable hotspot that travels in a circle and can stop only at 0 or 180 deg. which controls a single boolean parameter. Thanks.
    Geoff Briggs
    DeForest Architects
    Seattle, USA
  • #2048
    Hopefully this will help.
    I have just cut this from an object I use to set appliance models and cut-out sizes.
    I have left just the parts for a stretchable on/of style hotspot and also a rotating hotspot.
    The rotating hotspot has 4 positions rather than just the 2 you want.
    If just a choice of two settings I use the straight stretchy method.
    You can amend the rotating one to have as many or as few options as you want.
    And obviously change the names of the parameters so they mean something to you.
    I did this in a bit of a rush so haven’t altered the names to anything more generic.
    Barry
  • #2051
    Geoff Briggs
    Thanks Barry,
    Normally I would agree about using a sliding arrangement for simple on/off but I have reason to use the rotating shape in this instance. And no worries about cleaning up the names and such, I’m just looking for good example to save some trial and error.
    Thanks again, cheers.
    Geoff Briggs
    DeForest Architects
    Seattle, USA
