Home › Forums › Problems and solutions in GDL › Documentation elements, text handling › Section Marker Tail
- This topic has 9 replies, 3 voices, and was last updated 8 years, 4 months ago by
Bruce Walker.
January 27, 2018 at 08:05 #3765
Bruce Walker
ParticipantCan someone point me in the right direction to figure out how to test which end of the section line is being drawn?
I want to create a section marker that will put a ‘tail’ on one end, instead of the head. I know it can be done, as I’ve seen a couple of examples of it in action – unfortunately I am not able to get my hands on these to have a look at the script (and GS doesn’t have a part that does this). I can’t find anything in the GDL reference guide, or the GDL Cookbook.
Any clues?
Cheers,
www.brucepwalker.com
NVIDIA GeForce GTX 1060 8Mb -
January 27, 2018 at 13:23 #3766
ParticipantA section marker is drawn twice — the second time it is mirrored, and the SYMB_MIRRORED global is 1. By testing this global you can draw the head and tail once each. Then I have a checkbox parameter to flip the head and tail if desired.
January 28, 2018 at 05:27 #3767
Bruce Walker
ParticipantThanks – this is exactly what I’m after. Thanks for that.
January 28, 2018 at 20:25 #3768
Bruce Walker
ParticipantOne more question: how do you hide the part of the section line that crosses the head (see image)? I’ve had a look at the GS part, but nothing stands out.
January 31, 2018 at 08:12 #3789
Bruce Walker
ParticipantCan someone from GS help me here? The Built-in Section Marker does this, but I can’t figure out how.
February 6, 2018 at 20:12 #3799
Bruce Walker
ParticipantI would have thought this was an easy one.
I have compromised, and inserted an ADD2 command to move the head away from the section line end. Not my preference, as this means the marker requires even more space on the sheet, but I can’t figure out how the Built-In Section Marker achieves this.
February 6, 2018 at 21:03 #3800
ParticipantI have mine offset from the origin — the line meets the corner of the triangle. The built-in one uses a masking fill inside the circle. (It’s the window background color by default, making it impossible to see).
February 6, 2018 at 22:01 #3801
Bruce Walker
ParticipantI don’t see how this works, as:
1. The section line is drawn in front of the marker head, so masking fills have no effect (not that I can figure)
2. Even when the masking fill is turned off, the section line goes to the edge of the marker.?? Confused.
February 19, 2018 at 11:19 #3822
KeymasterYou need to set/use the AC_MarkerSize parameter correctly, it will shorten the line to the proper length.
February 22, 2018 at 19:56 #3839
Bruce Walker
ParticipantThanks Gergely – very helpful. I didn’t think to check the template parameters for a logical setting.
Unfortunately, it turns out that the AC_SectionLineStartOffset parameter will set the start for both ends – I can’t test with a SYMB_MIRRORED to shorten one end and not the other.
Never mind – good to know! Thanks again for your help.
