Sense the change of object ID
Home Forums Problems and solutions in GDL Parameter connections Sense the change of object ID
    • #4195
      Piotr Dobrowolski
      Is there a way to check if the ID of the object changed?
      There is GLOB_ID parameter but there is no way to check if it changed.
      I need this in masterscript or parameter script.
      Piotr
    • #4196
      Piotr Dobrowolski
      OK I will answer myself.
      Looks like it is wired: if GLOB_MODPAR_NAME=GLOB_ID” just worked…
      So in the “previous” (first) run there must be temp parameter prepared say: TEMP_IDX where the previous state of ID is stored (can be of course empty for the start)
      then:
      if (GLOB_ID#TEMP_IDX) then
      will mimic the missing parameters change check.
      Piotr
  • The forum ‘Parameter connections’ is closed to new topics and replies.
