Split Function Problem
Home Forums Problems and solutions in GDL Object design Split Function Problem
    • #3982
      James Goode
      I am trying to use the split function on parameter obtained from a home story request function.
      What I want to achieve is to show just the GF instead of GF-Ground Floor.
      x = REQUEST ("Home_story", "", index, story_name)
      n = SPLIT (story_name, "%s-%s %s", num)
      IF n THEN
          text2 0, 0, num
      ENDIF
      This is what I have so far. It removes the “Floor” part of the code but I don’t know how to get it to remove the “-Ground” part of the output
      Any help would be appreciated,
      Thanks
    • #3985
      If your storey name is “GF-Ground Floor” then you will find that “GF-Ground” is one part of the string and “Floor” is another.
      So …
      x = REQUEST (“Home_story”, “”, index, story_name)
      n = SPLIT (story_name, "%s %s", split1, split2)
      IF n THEN
          text2 0, 0.5, story_name
          text2 0, 0, split1
          text2 0, -0.5, split2
      ENDIF
      What you actually need to do is search for the “-” character.
      Assuming this is the same for all your storeys.
      Then output the required number of characters.
      pos = STRSTR (story_name, "-")
      !    text2 0, 0, pos
      prefix = STRSUB (story_name, 1, pos-1)
          text2 0, -2, prefix
      Of course if the prefix is always 2 characters you know this already so you can just output the first 2 characters with STRSUB.
  • The forum ‘Object design’ is closed to new topics and replies.
