"Standing" prism?
Home Forums General discussions "Standing" prism?
This topic contains 4 replies, has 3 voices, and was last updated by  Mats Knutsson 5 months ago.
  • #18732
    Mats Knutsson
    What is the best 3D-shape to use if I want a to model something that in section is controlled like a poly and then just extruded (adjusting thickness)? I can use prism but then I have to rotate it so it stands up and for me it feels like kind of unnecessary. I’m creating my first macro and it’s a support column to which I want to send the thickness with the macro call. Maybe the rotated prism is the correct way but I wanted to check with you guys first.
    Br,
    Mats
  • #18733
    RULEDSEGMENTED can be used for sideways extrusion, but I think rotating a prism is easier. GDL commands are designed to be used with transformations, there aren’t duplicates for different directions.
  • #18738
    David Shorter44
    Mats, I cant visualise what you’re trying to create but have you tried using the new column tool or a complex profile?
    These days its better to use an element rather than an object if its possible.
    D
    ArchiCAD 4.1-22
    MacBook RetinaDisplay
    16Gb RAM 500Gb SSD
    BIMXdocs
    • #18747
      Mats Knutsson
      David: boilers of varoius sizes accordin to attach. Differens kettle sizes byt more or less the same support structues on the sides. The kettle and the shower I will not dabble with but as an excercise I’d make the kettle, shower as dumb macro calls and the supoprts as smart ones (only differens thickness).
The forum ‘General discussions’ is closed to new topics and replies.
