Stop label mirroring on Hotlinked Module
Home Forums Problems and solutions in GDL Documentation elements, text handling Stop label mirroring on Hotlinked Module
Viewing 6 reply threads
    • #3402
      Kristian Bursell
      When my label is placed on the wall of a room and that room is imported as a hotlink and then mirrored, the label is mirrored also. Obviously you have resolved this issue for your labels so can you please tell me how.
      I also had the problem with hotlinked being rotated on an angle but i fixed that by using the methods in your labels. However i can find where you resolved the mirroring issue.
      Thanks,
      Kristian
      CADSWIFT
      Australia
    • #3411
      Csilla Mai
      Hi Kristian,
      Please add some more information about this mirroring problem.
      The problem only appears in hotlinked modules? If you mirror a room with the labeled wall within a .pln file, do you get the expected result?
      Could you send a picture of the Label, which behavior would you like to follow in case of mirrored hotlink? And could you please send a picture of your label’s current behavior?
      Csilla Mai
    • #3451
      Kristian Bursell
      Hi Csilla,
      It seems i’m not getting email notifications of replies from this site.
      Anyway, i was a bit lazy on this as it was a request from a client i didn’t want to spend too much time testing. I checked and it doesn’t matter if it is hotlinked or not. if i mirror a room it has the same affect. So obviously this puts the blame on the “Flip wall on reference line” function. So all i need to do is find out what side of the reference line to wall is on. I will search the GDL guide for value to reference but if you know the script in need could you please let me know.
      Thanks
      CADSWIFT
      Australia
    • #3452
      Hi Kristian,
      You can use RSS to check the forum answers, use this url: http://gdl.graphisoft.com/forums/feed.
      As I know, there is no solution in GDL to check the wall’s refline’s side in the current version – so the “flip” option is a known workaround, which is far from perfect in some situations…
    • #3591
      Andreas Åkerlund
      Hi
      Gergely, do you know why or more importantly, when we can hope to be able to script wich side the reference line is on?
      /Andreas
    • #3602
      Andreas,
      Why? – It is simply not developed yet… We have a lot of requests each year, and until v21 we always had more important developments on the list.
      When? – I’m not able to give you details about the upcoming versions on this forum, sorry. We know, that there is a wish for that, it is on the long list of wishes, but I can not promise anything.
    • #3764
      Bruce Walker
      Given you’re just concerned with the label, can you use the SYMB_MIRRORED test?
      www.brucepwalker.com
      NVIDIA GeForce GTX 1060 8Mb
  • The forum ‘Documentation elements, text handling’ is closed to new topics and replies.
