Tapered square shape
Home Forums Problems and solutions in GDL Object design Tapered square shape
This topic contains 1 reply, has 2 voices, and was last updated by  Péter Baksa 5 months ago.
  • #4345
    Is there a shape that can build a tapered square profile that renders correctly in OpenGL?
    As far as I can tell, all the shapes with 0, 1 status (PYRAMID, SWEEP, TUBE, etc) render like it is assumed the shape is rounded. Same for MASS and HPRISM_.
    The attached image is a SWEEP on top of a PRISM_. The tapered portion should have square corners like the base, not be ‘smoothed’ or whatever.
  • #4347
    pyramid works for me:
    addz 5
    cutplane
    del 1
    pyramid 4, 10, 1 + 4 + 16,
    		-1, -1, 0,
    		 1, -1, 0,
    		 1,  1, 0,
    		-1,  1, 0
    cutend
