Home › Forums › Problems and solutions in GDL › Parameter connections › Testing for D_iSlidingType in LibraryGlobals13
- This topic has 5 replies, 3 voices, and was last updated 9 years, 4 months ago by
Gergely Fehér.
September 11, 2016 at 21:36 #2713
Bruce Walker
ParticipantI’m having trouble getting an accurate return value to test the “Line Shape – Sliding Doors” MVO. I’ve used the code:
success = LIBRARYGLOBAL ("LibraryGlobals13", "D_iSlidingType", bOplinesTemp)Success will return 1, but bOplinesTemp will always be 0, regardless of what the actual value is. This code works fine (using parameter name “D_showBOpLine3D”) for the “Show Opening Lines in 3D Projections,” so I’m not sure what I’m doing wrong.
www.brucepwalker.com
NVIDIA GeForce GTX 1060 8Mb -
September 12, 2016 at 21:47 #2721
Bruce Walker
ParticipantThis is happening to quite a lot of LIBRARYGLOBAL requests e.g. minimal space (on/off; pen; line type). I have copied the code directly out of the GS door macro to ensure I have it correct…but it still doesn’t work. I cannot figure out why.
Have tested in AC19 and AC20, next to a GS door. The GS door will work, but mine won’t.
Any help would be appreciated.
September 12, 2016 at 22:04 #2722
Bruce Walker
ParticipantFigured it out: for some reason there are two LibraryGlobals13 loaded in the library: one for AC19, the other for AC17.
Still doesn’t answer the question why the GS door worked though.
September 13, 2016 at 02:43 #2723
ParticipantStill doesn’t answer the question why the GS door worked though.
I am guessing the GS door knew to use the LibraryGlobals13 file for the 19 library and your doors would have been using the other one.
You will probably see two GDL options in your MVO dialogue.I know when you CALL a macro by name it actually compiles the GUID into the script (although we only see the name).
Once saved you can rename the call macro file in your operating system and the object will still find the correct macro even though it is calling the old name.So I am assuming the same is happening with the LIBRARYGLOBAL command – each was linked to the GUID for their respective macro file.
I may be wrong.Barry.
September 13, 2016 at 03:55 #2725
Bruce Walker
ParticipantSounds good. I saw the second MVO tab and removed it from the library – works fine now.
Regarding the GS door – further clarification: it would turn ON the minimal space no trouble, but to turn it back off I had to select a MVO Combination. I couldn’t just open the MVO and turn off the minimal space, as that would have no effect.
So it could be a combination of both GUID, and order of ‘scrolling’ through the LIBRARYGLOBAL calls.
Anyway – lesson is don’t have two LibraryGlobals13 loaded!
September 13, 2016 at 21:48 #2727
KeymasterHi Guys,
Barry got it right: GDL scripts contains the name of macros, and when you save an object then AC looks for that by it’s name, and saves the macro’s GUID to the caller object. If you have more than one macros loaded with the same name, then the behaviour will be unpredictable: AC will use the first object with the name – and store it’s GUID to the caller. And yes, it can change save by save, depending on million things.
So the proper way of developing any libraries is to do not have duplicate names with libparts/macros loaded together…
- The forum ‘Parameter connections’ is closed to new topics and replies.
