Text in Array…
Home Forums General discussions Text in Array…
    • #4368
      Hi !
      i would like to have text in Array[1][1] to Array[3][9] from an external file (i’m okey with i/o text add-on), it’s okey with numbers but i don’t find solution to have text in arrays…
      Could you help me please ?
      Thanks a lot !
      fredLB/
    • #4465
      Good morning !
      i need to import from EXCEL a large numbers of columns and lines, i need to find lines by ‘keywords’ by the VALUES function, but… i don’t find…
      1/ my EXCEL file is exported in TXT file with /t separator.
      2/ i can read all the file from the TEXT Add-on in GDL and separate each data.
      3/ i create keywords with the VALUES function.
      4/ … and i don’t find how to use these keywords to search special lines in my TEXT file to record in ARRAYs (several columns and lines with strings and numbers)
      i have tried with DATA Add-on and with TEXT Add-on, but i don’t understand.
      Thanks !
      fredLB/
    • #4467
      could you post the code that is already working, and a sample of the structure of the text file?
