Text rotation in labels
This topic contains 4 replies, has 3 voices, and was last updated by  Bruce Walker 9 months ago.
  • #4756
    I am wondering if it is possible to force text to remain level regardless of the Label Rotation: Orientation setting. (Similar to rotating text in an ordinary object depending on the state of V~ and W~) Does the parameter AC_bLabelAlwaysReadable have something to with it?
  • #4757
    Read about controlling labels here, label ac_ parameters here, label globals here.
    If you need it to remain horizontal independent of plan rotation, use the “View_Rotangle” request.
  • #4774
    Bruce Walker
    Here is some sample code I find works. It also accounts for view rotation. ‘txt_font’, ‘txt_size’ and ‘txt’ are parameters:
    DEFINE STYLE 'txt1Style' txt_font, txt_size, 5, 0
    !View rotation angle
    rrr = REQUEST ("View_Rotangle", "", angleViewRot)
    totRot = (SYMB_ROTANGLE + angleViewRot)
    IF totRot > 360 THEN totRot = totRot - 360
    STYLE txt1Style
    TEXT2 0, 0, txt
    www.brucepwalker.com
    NVIDIA GeForce GTX 1060 8Mb
  • #4829
    That adjustment doesn’t seem to correct for when the label is at an angle, see image.
  • #4834
    Bruce Walker
    The text is still orienting correctly within the context of the label – it’s the label itself that is rotated. You will need to use the LABEL_ROTANGLE (I think) to always keep the text horizontal. Haven’t looked into it myself, but that’s where I’d start.
