Understanding STR
Home Forums Problems and solutions in GDL Others Understanding STR
This topic contains 1 reply, has 2 voices, and was last updated by  Gergely Fehér 2 years, 8 months ago.
  • #3596
    David Seabury
    I have an object that we use to generate data for our surveyor.
    we schedule these objects and then convert them into a plain text
    file for their use.
    The problem I am having is the script does not work if a generated
    value is less then 1 EXAMPLE (X VALUE), (Y VALUE), (Z VALUE)
    1.2345, -.1234, 12.3456
    is scheduled as 1.2345, -1,234, 12.3456
    The y value is wrong.
    I am sure it is due to the STR script I am using, but I am not sure which value needs to be changed.
    Any insight would be appreciated.
    The following is located in the properties script.
    component “XYZ,” + str(“%#10.4df”,SYMB_POS_X) + “,” + str(“%#10.4df”,SYMB_POS_Y) + “,” + str(“%#10.4df”,SYMB_POS_Z), 1, “m”
    Thanks
    David
  • #3601
    David,
    I could not reproduce the issue. Can you send us a pla in mail (gdlcenter@graphisoft.com), with the following information: AC main version, build number, localization, platform?
    Thanks.
