Unique Parameter button
Home Forums Problems and solutions in GDL Parameter connections Unique Parameter button
This topic contains 1 reply, has 2 voices, and was last updated by  Barry Kelly 2 years, 4 months ago.
  • #3399
    Does it work at all? I am trying to exclude parameters from eyedropper/syringe transfer. They seem to be transferring anyway. This includes built in parameters such as A & B as well as my parameters. What am I missing?
  • #3403
    It seems it only blocks the transfer when you transfer to a new object in the object settings (it is the new object that must have the unique parameter exclusion set so as not to accept that parameter).
    It has no effect when transferring between existing objects.
    I am not sure this was always the case but I may be mistaken as I rarely use it.
