Use buttons to select variable from a parameter
Home Forums Problems and solutions in GDL Graphical UI and parameters list Use buttons to select variable from a parameter
Viewing 4 reply threads
    • #18647
      James Goode
      How can I have 3 separate buttons that can select a different option from the same parameter?
      This is code that I’ve adapted from another object I have. Any help is appreciated.
      ui_infield{3} "existing", 0, 100, 100, 20,
      	5, "", 1, 1,
      	100, 100, 100, 100,
      	1, e1,e1
      	ui_infield{3} "existing", 0, 130, 100, 20,
      	5, "", 1, 1,
      	100, 100, 100, 100,
      	1, e2,e2
      	ui_infield{3} "existing", 0, 160, 100, 20,
      	5, "", 1, 1,
      	100, 100, 100, 100,
      	1, e3,e3
    • #18648
      Do you mean something like UI_Radiobutton?
      MAC OSx 10.12
      • #18651
        James Goode
        Yeah kind of, I know that I can use those circular radio buttons but what I really want is a button similar to the ui_button where it’s a solid rectangle so I can have 3 of them and each button will activate a different option.
    • #18652
      Method 5 is a simple pushbutton, it only has on/off states.
      With method 4 or 6 more states are available, but you have to draw the pictures on the buttons, just giving a string is not possible.
      All options go in the same statement:
      	4, "", 0, 0,
      	0, 0, 0, 0,
      	0, "one", 1,
      	0, "two", 2,
      	0, "three", 3
      And setting the options in parameter script is also necessary:
      values "existing" 1,2,3
      To use strings code many boolean buttons, which are conected in the parameter script and only one of them can be selected.
      • #18656
        James Goode
        Thanks for your reply. This doesn’t really do what I need, I need separate buttons that are apart from each other that activate a different option.
        Is there a way to create a boolean button that looks the same as a UI_button?
        Thanks
    • #18657
      This is a boolean exampe with 1 button:
      UI_INFIELD{3} “b_MVO_endgroesse”, 0, 0, 25 ,25,
      6, Tree_MVO_3, 2, 1, 25, 25, 25, 25,
      1, “”, 0,
      2, “”, 1
      But I am not shure if this looks the same as a UI_Button.
      The grafic file Tree_MVO_3 is embedded, if you use an external it must be “Tree_MVO_3” or similar.
      This file has 2 grafics beside each other, one for the Value zero, the other for the value 1.
      MAC OSx 10.12
    • #18659
      And yes, there are special boolen buttons as well, which look a bit different than the example before:
      UI_PICT_PUSHCHECKBUTTON “myBool”, “myText”, “myPict”, 1, 0, 110, 100, 30
      MAC OSx 10.12
  • The forum ‘Graphical UI and parameters list’ is closed to new topics and replies.
