When using WALLHOLE2, how do you get the wall contour line at the ends while the MVO is Show Opening Only? The Simple Door Opening shows the lines. The manual says that WALLHOLE2 polygon doesn’t have a contour, but how do you get it?
Use the WALLLINE2 command to draw the missing wall lines back. ”Show Opening Only” option does not affect lines created with this command.
Example can be found in WallholeCut macro in ARCHICAD Library.
Zsolt Feke
Library Developer, Library Team GRAPHISOFT SE
It seems that WALLLINE2 does not respond to DRAWINDEX. I had my heavy cut lines drawn in front, and when I changed LINE2 to WALLLINE2, they fell back. Is there anything to do about this?
DRAWINDEX does not affect WALLLINE2 (the same applies to all WALL type component commands). The only way to workaround this is to manipulate scripted order.
Zsolt Feke
Author
Viewing 4 reply threads
The forum ‘Doors and windows’ is closed to new topics and replies.
