WALL_​​ID
Home Forums General discussions WALL_​ID
This topic contains 3 replies, has 3 voices, and was last updated by  Péter Baksa 1 year, 4 months ago.
  • #4395
    Hi !
    in AC20, the WALL_ID function was okey, i can’t use this function in AC22… ?
    And of course, i need to use the same function to read the ID of doors, windows, slabs, how can i do in AC22 ?
    pliizzzzz….
    Thanks a lot !
    fredLB/
  • #4397
    What do you mean on “I can’t use this function”? In what libpart type, and what script type? What do you mean on “read the ID of doors”? Read from a label? Property object?
  • #4464
    i place my object on a wall, i would like this object to import the ID of the wall, and the same for windows, doors…
    fredLB/
  • #4466
    WALL_ID is only available in labels, doors and windows, there has been no changes that I know of.
    What is the code that worked for you in AC20 and not in AC22? What is the subtype of the object?
