WALL_​​SKINS_​​BMAT_​​NAMES
Home Forums Problems and solutions in GDL Informations from the environment WALL_​SKINS_​BMAT_​NAMES
Viewing 5 reply threads
    • #1755
      What’s the correct usage of this global? I assume the content is a string, so I’m trying to assign it to a string variable like so:
      stringParam=""
      stringParam=WALL_SKINS_BMAT_NAMES[1]
      But I get a warning of ‘Incompatible Array Definitions’. I can PRINT the global’s content and it reads correctly in the report.
    • #1758
      James,
      this global has one column and a number of rows equal to the skins number, so the form is:
      WALL_SKINS_BMAT_NAMES[nSkins][1]
      The WALL_SKINS_NUMBER global returns the filled rows number of WALL_SKINS_BMAT_NAMES, and you can use it for running the iteration.
      Try the following code (copy it to a window’s 2D script):
      text2 0, 2, "vardim1(WALL_SKINS_BMAT_NAMES) = "
      text2 7, 2, vardim1(WALL_SKINS_BMAT_NAMES)
      text2 0, 3, "vardim2(WALL_SKINS_BMAT_NAMES) = "
      text2 7, 3, vardim2(WALL_SKINS_BMAT_NAMES)
      text2 0, 4, "WALL_SKINS_NUMBER = "
      text2 7, 4, WALL_SKINS_NUMBER
      for ii = 1 to WALL_SKINS_NUMBER
      	text2 10, ii*1, WALL_SKINS_BMAT_NAMES[ii][1]
      next ii
      The PRINT command iterates through any array global without worrying about the array dimensions, that’s why it was working.
    • #1761
      Thank you!
    • #1961
      Heimo Mooslechner
      I have some problems with this parameter and the correct usage..
      i wrote:
      OFT = WALL_SKINS_NUMBER
      i=1
      for ii = 1 to oft
               WSP[ii] = WALL_SKINS_PARAMS[ii][1]                 !Schraffur
               KernSTR = STR(WALL_SKINS_PARAMS[ii][6], 1,0)
               Kern = WALL_SKINS_PARAMS[ii][6]
                  WSBN[ii]=WALL_SKINS_BMAT_NAMES[ii][1]            !Baumaterial
                  add2 0.15,0.02
                     style links
                     t = REQUEST{2} ("Building_Material_info", WSBN[ii], "gs_bmat_surface", oberflaechen[ii])  !!S378
                     r = REQUEST ("Name_of_material", oberflaechen[ii], name[ii])
                  del 1
                  if ii = 1 then Aussenputz = oberflaechen[ii]
                  if ii = oft then Innenputz = oberflaechen[ii]
               s=request("Name_of_fill",WALL_SKINS_PARAMS[ii][1],Schichtnamen[ii])
               !Schichtnamen[ii]=WSBN[ii]
               Schichtdicken[ii]=WALL_SKINS_PARAMS[ii][2]      !Dicke
            if KernSTR="3" then
               WoKern = ii
               else
               Gesamtdicke = Gesamtdicke  + Schichtdicken[ss]
            add2 0, -0.015
      next ii
      del oft-1
      for ss = 1 to WoKern-1
         Dickensumme = Dickensumme + Schichtdicken[ss]
      next ss
      in the 2D-Script – i got correct answers from it.
      there i wrote:
      for ii = 1 to oft
         add2 0, 0.05
         text2 0,0,oberflaechen[ii]
         Text2 0.2,0, Aussenputz !! nur als Test - schreibt brav 18 hin
      next ii
      del oft-1
      BUT – in the 3D-Code – i got Just 0 when i tried the same – and there i would need it so badly…
      i wrote in 3D:
         DEFINE STYLE test "Arial", 10, 1, 0
         style test
          for ii = 1 to oft
            addy -0.012
            addz 0.1
                    text 0, 0,oberflaechen[ii] - !!nur als Test - da schreibt er gar nichts hin
               TEXT 0.01, 0, Aussenputz !! sollte überall 18 stehen - aber macht im 3D  0 draus
            del 1
         next ii
         del oft
      Why is it not functional in 3D?
      I personal would need it for self made wall-openings with much more editable hotspots than are used in the normal Archicad-library.. for a much better user-experience..
      Teacher in HTL-Salzburg
      AC5-19, Win and Mac
      GDL hobby developer
    • #1968
      WALL_SKINS_BMAT_NAMES works only in 2D. In 3D you can use WALL_MAT_A and WALL_MAT_B.
      Note: when you paste codes with loops, please use other variables than “i” or “s” as these characters with brackets will be eliminated as they are interpreted as BBCodes. I changed them in your code snippets to “ii” and “ss” for a better understanding. You can read more about BBCodes here: http://gdl.graphisoft.com/forum-functions/
    • #1969
      Heimo Mooslechner
      Thank You for Your reply. In the meantime – i figured the WALL_MAT_A and WALL_MAT_B out by myself – and took it as a workaround for the limitation of WALL_SKINS_BMAT_NAMES in3D. This should really be changed in further AC-Versions.. i think.
      And thanks for the suggestion for using “ii” instead of “i” – i will make it so in future. Do i understand it right – this BBC is limitation for this forum – not for the GDL?
      AC5-19, Win and Mac
      GDL hobby developer
      • #1970
        Yes, this limitation with the variable names is only for this forum – in ARCHICAD you can use any variables.
  • The forum ‘Informations from the environment’ is closed to new topics and replies.
