Home › Forums › Problems and solutions in GDL › Lists and schedules › Where I get the idxSkin?
Tagged: complex profile, component, property librarie
- This topic has 6 replies, 3 voices, and was last updated 7 years, 8 months ago by Gergely Fehér.
October 9, 2015 at 01:58 #1685carlos lopezParticipant
I am creating an property object to a wall of complex profile, for that I make a Request of skins,
REQUEST (“COMPONENT_VOLUME” idxSkin, skinVolume)
I have a question where I get the idxSkin
building material?
Priority?
Fillings of complex profile?
Hopefully someone can help me, thanks. -
October 9, 2015 at 16:50 #1695Gergely FehérKeymaster
idxSkin is the index of the skin to which you would like to get the volume. Unfortunately, this index is a bit tricky, it starts from 0 and must be smaller then WALL_SKINS_NUMBER. You can use the following code to get all skins volume and area from a composite wall:
for i = 1 to WALL_SKINS_NUMBER success = REQUEST ("COMPONENT_VOLUME", i-1, skinVolume) component "volume " + WALL_SKINS_BMAT_NAMES[i][1], skinVolume, "m3" success = REQUEST ("COMPONENT_PROJECTED_AREA", i-1, skinArea) component "area " + WALL_SKINS_BMAT_NAMES[i][1], skinArea, "m2" next i
I hope it helps.
GRAPHISOFT SE-
March 31, 2016 at 08:13 #2360Narendra SuryavanshiParticipant
Hello Gergely Fehér,
Many thanks for code.
However will you tell me the formula to find number of skins of a beam/ or a column having complex profile/s.
Thanks in advance.
Naraindrra SurryavanshiThanks in advance
April 1, 2016 at 09:52 #2365Gergely FehérKeymaster
Getting the number of skins can be done with a do – while code block, as there is no dedicated global for it in these 2 element types. Unfortunately there is no global for the used building materials like WALL_SKINS_BMAT_NAMES.
nSkins = 0 do success = REQUEST ("COMPONENT_VOLUME", nSkins, skinVolume) if success then nSkins = nSkins + 1 while success
October 11, 2015 at 03:30 #1697carlos lopezParticipant
I finally found as the skins are indexed in the complex profile, the idxSkin index number of each component corresponds inversely to the drawing sequence of fillings.
The system assigns the last fill the number 0.
I LEAVE AN IMAGE TO SEE AS interprets the code GDL.THANKS Gergely Fehér I SERVED ME YOUR EXAMPLE, TO TEST
August 4, 2016 at 10:07 #2652Narendra SuryavanshiParticipant
I am using your code for listing components of complex profiled wall, But not all components are returned by the program. In additions some quantities are wrong.Unable to understand. I cannot attach the PLA file for you due to restriction on size of attachments here. I tried to use the code over “Brick wall” which lies in the default profile of Ver 19.(Enclosing image and list output for your reference.)
Repeating the code for youfor i = 1 to WALL_SKINS_NUMBER success=req("WALL_SKINS_BMAT_NAMES[i][1]") success = REQUEST ("COMPONENT_VOLUME", i-1, skinVolume) component "volume"+WALL_SKINS_BMAT_NAMES[i][1], skinVolume, "m3" success = REQUEST ("COMPONENT_PROJECTED_AREA", i-1, skinArea) component "area "+WALL_SKINS_BMAT_NAMES[i][1],skinArea, "m2" next i
As this happens for all the complex profiles it becomes large issue.
Thanks in advance.
NS -
August 9, 2016 at 14:35 #2660Gergely FehérKeymaster
The line success=req(“WALL_SKINS_BMAT_NAMES[1]”) is absolutely useless, first try to delete it. If it does not help, then send me a sample file in mail please.
- The forum ‘Lists and schedules’ is closed to new topics and replies.
