Home › Forums › Problems and solutions in GDL › GDL add-ons › Write text file to embedded library
- This topic has 21 replies, 2 voices, and was last updated 7 years, 7 months ago by
James Goode.
October 15, 2018 at 13:17 #4291
James Goode
ParticipantHello,
is it possible to write a text file to the embedded library?
Thanks
October 16, 2018 at 08:09 #4292
KeymasterHello,
yes it is possible, with limitations:
– new files can’t be created
– writing is only possible after version 17
– after version 18 writing is only possible from the UI, Parameter or Property scriptschannel = OPEN ("TEXT", "data.txt", "SEPARATOR = ' ', MODE = WO, LIBRARY") OUTPUT channel, row, column, value close channelPéter Baksa
October 16, 2018 at 10:45 #4293
James Goode
ParticipantFor the object I’m creating, I want to be able to output the symb_pos_x & y of that object. Can that be sent to the embedded library?
October 16, 2018 at 11:03 #4294
James Goode
ParticipantI also want to then read that value in a different file
October 16, 2018 at 11:25 #4295
KeymasterYes, it can. You have to add the “data.txt” (or other filename that you are using) to the embedded library first.
Another limitation is that in teamwork the user needs to reserve the file to be able to write to it.
October 16, 2018 at 11:27 #4296
James Goode
ParticipantI can’t seem to get my object to write the symb_pos_x and symb_pos_y to the file at all. My other object can definitely read the file though.
this is my code for OUTPUT
chOUT=OPEN ("TEXT", "SurveyPoint.txt", "separator =' ', MODE=WO, LIBRARY") OUTPUT chOUT, 1, 1, symb_pos_x OUTPUT chOUT, 2, 1, symb_pos_y OUTPUT chOUT, 3, 1, symb_pos_z close chOUT -
October 16, 2018 at 11:58 #4297
James Goode
ParticipantI’ve got it reading and writing correctly but I get error reports saying Cannot modify the file in embedded library in 2D script type, Nonexistent channel and Open error while operating on the file
October 16, 2018 at 13:06 #4298
James Goode
Participantare you able to write to a library from within a pla?
October 16, 2018 at 13:38 #4299
KeymasterNo, in 2D / 3D script you can’t write. Only UI, Parameter or Property scripts.
.pla should work.Péter Baksa
October 16, 2018 at 15:29 #4300
James Goode
ParticipantIs it possible for me to output the symb_pos_x and y without the output being in the 2D script?
October 16, 2018 at 17:41 #4301
KeymasterPreviously I tested your idea with print commands, all worked nice, but now I see that the values don’t get written to the data file.
The problem is that even if the parameter script is run when you move the object, or open the settings, it runs in a sandboxed mode, and the changes won’t be applied unless any parameter changes.
If you change some hidden parameter, eg. increment a counter, it will work – interestingly, toggling a boolean isn’t enough, maybe because the param script runs even number of times.
GRAPHISOFT SE-
November 12, 2018 at 14:54 #4324
KeymasterWith further inspection I’ve found that this is not an usable solution:
the parameter script could be run not just for the placed object, but as a mockup-object of the settings dialog. This can overwrite data very easily, eg. changing the library part of the object tool, selecting another object on the floor plan, viewing favorites, or changing to a different tool.Péter Baksa
November 7, 2018 at 15:06 #4315
James Goode
ParticipantHello,
I have got this working perfectly apart from the fact that I receive an error when placing my object that writes the file.
It still works, but the error is stopping us from progressing with it. -
November 7, 2018 at 16:03 #4316
KeymasterHi, what is the error message?
November 7, 2018 at 16:05 #4317
James Goode
ParticipantThere are several. This issue is that it definitely works.
Nonexistent channel at line 68 in the 2D script of file Survey Point Output.gsm. Nonexistent channel at line 69 in the 2D script of file Survey Point Output.gsm. Nonexistent channel at line 70 in the 2D script of file Survey Point Output.gsm. Nonexistent channel at line 71 in the 2D script of file Survey Point Output.gsm. Cannot modify the file (filelog.TXT) in embedded library in 2D script type. Open error while operating on file 'filelog.TXT'. Nonexistent channel at line 68 in the 2D script of file Survey Point Output.gsm. Nonexistent channel at line 69 in the 2D script of file Survey Point Output.gsm. Nonexistent channel at line 70 in the 2D script of file Survey Point Output.gsm. Nonexistent channel at line 71 in the 2D script of file Survey Point Output.gsm. Cannot modify the file (filelog.TXT) in embedded library in 2D script type. Open error while operating on file 'filelog.TXT'. Cannot modify the file (filelog.TXT) in embedded library in 2D script type. Open error while operating on file 'filelog.TXT'. Cannot modify the file (filelog.TXT) in embedded library in 2D script type. Open error while operating on file 'filelog.TXT'. Cannot modify the file (filelog.TXT) in embedded library in 2D script type. Open error while operating on file 'filelog.TXT'. Cannot modify the file (filelog.TXT) in embedded library in 2D script type. Open error while operating on file 'filelog.TXT'. Cannot modify the file (filelog.TXT) in embedded library in 2D script type. Open error while operating on file 'filelog.TXT'. -
November 8, 2018 at 08:58 #4318
KeymasterDid you add “filelog.txt” to the embedded library?
New files cannot be created in the embedded library, you can only modify existing ones.Péter Baksa
November 8, 2018 at 10:59 #4319
James Goode
ParticipantYes I have
The error only pops up if I select either the writing or reading gdl object. -
November 8, 2018 at 11:09 #4320
James Goode
ParticipantI’ve also tried to get the file to write and read from a loaded library that isn’t the embedded but it still seems to try to write/read to the embedded library and throws up an error until I move it and then ctrl+shift+alt+R then it begins to work with both the reading object and the writing object. Here is the writing / reading code that I have in my objects;
Writing
chOUT=OPEN ("TEXT", "filelog.TXT", "MODE=WO, LIBRARY") OUTPUT chOUT, 1, 1, symb_pos_x OUTPUT chOUT, 2, 1, symb_pos_y OUTPUT chOUT, 3, 1, symb_pos_z close chOUTReading
chIN=OPEN ("TEXT", "filelog.TXT", "MODE=RO, LIBRARY") n = input (chIN,1, 1, zxzx) n1 = input (chIN,2, 1, zxzxz) n2 = input (chIN,3, 1, zxzxzx) close chIN -
November 8, 2018 at 16:49 #4321
KeymasterSorry, I don’t know what is the problem, your examples work fine for me.
GRAPHISOFT SE-
November 8, 2018 at 17:24 #4322
James Goode
ParticipantIs there any way I would be able to send you my files for you to take a look at?
Thanks
November 8, 2018 at 17:47 #4323
James Goode
Participantor do you have an example file that uses my examples that I could take a look at?
Thanks
November 14, 2018 at 15:07 #4333
James Goode
ParticipantProblem solved! As discussed, the issue was that I had the output in both the Parameter script and the 2D script. It was solved by removing the code from the 2D and keeping it in the parameter script.
- The forum ‘GDL add-ons’ is closed to new topics and replies.
