Zone accessories
Home Forums Problems and solutions in GDL GDL add-ons Zone accessories
This topic contains 4 replies, has 3 voices, and was last updated by  Joachim Sühlo 3 years, 6 months ago.
  • #2857
    How is it possible to create an object that is (by user definition) either an accessory part, that responds to a zone stamp or an independent object, that is detached from the zone stamp?
    MAC OSx 10.12
  • #2861
    I’m afraid it is not possible with only GDL programming. You can create an addon, which reads data from zone and stamp, and creates new objects based on that, or as a workaround you can put a slab into each zone, and use the slab accessory.
  • #2863
    BIMobject made such an object, but the script is encrypted.Polygon Source
    This works both as accessorie part when placed, and as user defined polygon after placing, that cannot be updated by the zone accessorie.
    MAC OSx 10.12
  • #2864
    Frank Studzinski
    Isn’t it the same method which is used by the old ADD-ON “Raumzubehör”?
    It’s still part of goodies.
    Graphisoft Berlin GmbH
  • #2865
    Yes, about the Addon “Raumzubehör” = “Zone Accessory” I am talking.
    There must be a switch to unlink the object from its Addon-Behavoiour.
    MAC OSx 10.12
