zone number counting value
Home Forums Problems and solutions in GDL Others zone number counting value
Viewing 3 reply threads
    • #3689
      Kristian Bursell
      I would like to add some values (prefixes) into the zone number but retain the automatic counting functions. Is this possible?
      I was hoping to find and autotext value or similar in GDL code that defines this counting value but i could not find anything.
      Thanks
      CADSWIFT
      Australia
    • #3690
      I just did a quick test by adding a prefix to the room number parameter in the zone object script.
      Automatic numbering still worked just fine.
    • #3693
      Hi Kristian!
      By automatic counting do you mean the auto-incrementation of zone no.?
      You don’t need autotext for that, just type your prefix before the number, and place the zones. Btw. this doesn’t work for postfixes. It might not work in all versions, I’ve tested this only with AC21.
    • #3712
      Kristian Bursell
      thanks Barry and Peter,
      it works if you just simply type the prefix in but I want to define th prefix in the GDL code based on several other parameter values. Therefore i need to set in the GDL code: parameters ROOM_NUMBER = prefix + counting function
      CADSWIFT
      Australia
