Home › Forums › Problems and solutions in GDL › Informations from the environment › zone stamp: default property settings
- This topic has 6 replies, 2 voices, and was last updated 4 years, 5 months ago by Péter Baksa.
November 6, 2019 at 19:40 #18351Joachim SühloParticipant
In the German default zone stamp you can choose to show properties.
When you open the object and want to set a special property as default (in the GDL editor),
this is not possible.
The zone stamp macro uses the code:UI_CUSTOM_POPUP_LISTITEM itemID, UIGroup, _paramContentIDbyRow[iUI], 0, “” , “”, 1, 3, 1, _displayedProperty,
“”, “”, “”,Keine
parentProperties`When I use instead the following, I can add default values in the editor:
ui_custom_popup_infield “sIDRow1_50”,
50, 244, 222,20, ! X Position, Y Position, Width, Height
1, ! Store Hidden ID
3, ! Tree Depth
1, ! Grouping Method
_displayName, ! Created value description
_parentPropertiesIs there a way to change the code in the first example, to allow the definition of fdefault values in the GDL editor?
MAC OSx 10.14 -
November 7, 2019 at 09:17 #18353Péter BaksaKeymaster
I couldn’t get the second one to work either.
The parameter list in the GDL editor is not connected to anything in the UI script, it is only affected by the parameter script.
You can’t get the property GUIDs in the parameter script, that’s why the UI_CUSTOM_POPUP_LISTITEM and UI_CUSTOM_POPUP_INFIELD were created.Péter Baksa
November 7, 2019 at 09:19 #18354Péter BaksaKeymaster
The property GUIDs are project-dependent, a default value of the library part wouldn’t work in another plan.
November 7, 2019 at 09:47 #18355Joachim SühloParticipant
the 2nd example had some Requests before. This code is from the gdl.graphisoft.com website.
In the example zone stamp both master and parameter script are empty.dim _parentProperties[]
n = REQUEST (“Properties_Of_Parent”, “”, _parentProperties)_displayName = “”
n = REQUEST (“Property_Name”, sIDRow1_50, _typeName, _groupName, _propertyName)
if _typeName # “” then _displayName = _typeName + ” : ”
if _groupName # “” then _displayName = _displayName + _groupName + ” : ”
_displayName = _displayName + _propertyName ! no need to check, always has a string valueui_custom_popup_infield “sIDRow1_50”,
3, ! Tree Depth
_parentPropertiesGDL Object Developer
MAC OSx 10.14 -
November 7, 2019 at 09:58 #18356Joachim SühloParticipant
Does this also applies to projects always created from the same Template file?
MAC OSx 10.14 -
November 7, 2019 at 10:12 #18357Joachim SühloParticipant
I checked this both with a pln, saving under a neww name and a tpl saving under a new name:
both works, the GUIDs stay the same.GDL Object Developer
MAC OSx 10.14 -
November 7, 2019 at 10:35 #18358Péter BaksaKeymaster
As long as the properties aren’t deleted by the user in Options / Property Manager.
