Barry KellyParticipant
I don’t know if they work or not.
I always forget to tick the box for notification.
I have ticked this one though.Barry.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantAutomigration is a special type for migration: it simply does an ID change, without running migration scripts. It is useful to eliminate migrations from new elements, and create step-by-step migration logic through many versions.
So to clarify, if we just want to migrate objects with no parameter changes, we just add the old object GUID to the list and turn on AutoMigration.
It will ignore anything in the migration script.Here is the link to the actual post Peter has quoted from Greg.
I had forgotten I was even a part of that conversation. (insert embarrassed face emoji here).https://archicad-talk.graphisoft.com/viewtopic.php?f=6&t=58220&p=274105&hilit=automigration#p274105
Thanks Peter and Greg.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantIt is all a bit of a mystery.
In the GDL manual STORED_PAR_VALUE and DELETED_PAR_VALUE seem to do exactly the same thing.
I figured I should use DELETED_PAR_VALUE if the parameter no longer exists in the new object, but I am guessing it doesn’t matter.I can find no reference as to what AutoMigration does, either here in the GDL Center or the Help Center.
Or if it is there it is just hard to find.I have always had AutoMigration turned off, so would never noticed it is a problem.
Also, I find it is easiest to use the ‘Migration’ section to find out the GUID of your new object.
You need the GUID of any old objects here – just don’t forget to delete the current object GUID once you have found out what it is and pasted to the migration script.
Otherwise the object will simply not migrate, and there will be no error messages to say why.Barry.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantI use DELETED_PAR_VALUE – that works for me.
So …
IF actualGUID = _startID THEN rrr = DELETED_PAR_VALUE ("aSurf", aSurf_val) ! get value from old bSurf = aSurf_val PARAMETERS bSurf = bSurf ! apply to new actualGUID = _endID ENDIF
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantThat’s what I get for looking at the 21 version of the book.
I still use the book from version 6.5 – as it was the last physical book printed and I find it much more convenient than opening a PDF.
Good job most of the basic stuff is still the same.
I just keep forgetting to look at the new options though.Barry.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantYes it is GLOB_PREVIEW_MODE = 3
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantThe only way I know of to control this globally for all doors would be to use Model View Options.
I see with the default Graphisoft library there is an MVO setting to show/hide the minimal space, but not to control the sizes.Or select all doors at once and make the changes you need (so long as the doors have been scripted with those options of course and they are not hidden).
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantWhen the override button is pressed it should show the override.
When the override button is not pressed it should show the BM surface.Isn’t that what I said?
I would like it to show the BM or nothing at all(if that is not possible) if the override is not pressed.Barry.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantI have never really liked the fact that the surface name is greyed out and you can actually see what is the ‘wrong’ surface.
But I know that it is then using the building material surface – but as David says you can’t see what this is.
It would be nice if it could show this or maybe not show anything at all until the override button is pressed.Some people still don’t even realise that is an override button.
Yes, complex profiles complicate it even more as it could be the building material used for the fill (not to mention there could be more than one fill on that surface), an overridden edge surface of the fill or the actual override of the entire wall itself.
Which is why I think it should be blank until the override button is pressed, and then it shows just the override surface.Barry.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantHi Peter
If you look at the upper part of the attachment the name “A001:Brickwork Face” appears but this is the override surface not the surface of the Building Material. The building material surface is correctly reported in the label text.That is correct.
The greyed out text is what the surface would be if the override was turned on.
When the override is not turned on, it doesn’t show the actual building material surface – which maybe it should?
Is that the problem here?
The label should always be correct.Barry.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantThanks Péter,
Drawing the end lines works but you don’t have the same control when the automatic wall hole is used.
Yes I can check ‘AC_WallContours’ and draw the lines or not.
But when I have 2 opening butting up next to each other, one with an opening extension because of a connecting column between the windows, and I need the side lines, there is a problem.
Drawing them manually they are either on or off – on in this case because I need the side lines.
With the automatic hole there is no joining line even when the side lines are on.Yes, I could script and control each side line separately, but I really don’t want to.
Hoping this fix will find it’s way into an update soon.
Thanks again.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantThank you.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitFebruary 28, 2019 at 02:41 in reply to: DESCTIVATING A CUTPLANE FROM 2D SCRIPT or similar method #4549Barry KellyParticipantIf you can get the correct views with the cutting planes in the PROJECT2 command then in the 2D script you use it twice.
PROJECT2 - top view with desired cutting planes if show_elevation = 1 then ADD2 x,y PROJECT2 - side view with desired cutting planes DEL 1 endif
If you need to use an actual CUTPLANE in the 3D script to get the projection you want then use the if/then command to control the CUTPLANE and CUTEND as I mensiomed before (but you won’t need the GLOB_VIEW_TYPE = 2).
The thing is you will need to turn off the CUTPLANE for one of the passes.
Again this may not be the best scripting but I would do this.show_elevation_orig = show_elevation show_elevation = 0 !!!!temporarily turn of show in elevation mode PROJECT2 - top view with or without built in cutting planes show_elevation = show_elevation_orig !!!!set elevation mode back to original if show_elevation = 1 then ADD2 x,y PROJECT2 - side view with or without built in cutting planes DEL 1 endif
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitFebruary 27, 2019 at 04:34 in reply to: DESCTIVATING A CUTPLANE FROM 2D SCRIPT or similar method #4533Barry KellyParticipantSo I need this, either:
a) A condition that can deactivates the CUTPLANE in the “3D script” when the user asks for an elevation view on Plan.I assume the showing of the elevation in plan view is a parameter option.
I would then do this.if elevation_in_plan = 1 and GLOB_VIEW_TYPE = 2 then !Plan view !!!!do nothing else CUTPLANE 0, cutplane_height endif ... 3D model script ... if elevation_in_plan = 1 and GLOB_VIEW_TYPE = 2 then !Plan view !!!!do nothing else CUTEND endif
I am sure it could be scripted differently.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantThanks Peter.
I don’t think a rotational and moveable hotspot can be linked which is why I was asking.
I will give your hidden calculations a go – I think that might be the only way.Usually with something like this I would have one hotspot for the origin x & y, another for the length and a rotation one at half the length.
