Barry KellyParticipant
Without actually writing the code all you need to do is create the script for the moveable (stretchy) hotspot – you can ad a rotating hotspot too if you want.
Then use an ADD2 command (and ROT2 command if desired) using the hotspot parameters.
Then TEXT2 0,0,”text” and the text will move with the hotspots.If you are not worried about moving the text differently for different scales and/or rotating then you can skip the ADD2 and ROT2 and use the hotspot parameters directly in the TEXT2 command.
If you need an actual coded example let me know.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantYour object is calling another object called “stages 45” in the 3D script.
I would be guessing this is in the embedded library of your original file which is why it works there but is not loaded in any new file which is why you are not seeing any 3D.
You need to export that object from the original embedded library and place it in your loaded library.Barry.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantI can confirm this and other strange things are happening in the script editor for 20.
If I copy and paste in the main script window it appears correct but it is not really working.
Look in the pop-out window and it is not there or something completely different happens which destroys the script.
It may look Ok but it isn’t.
Look at this simple example where I have copied and pasted a small piece of script.Barry.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantThanks for the fix.
Barry.Versions 6.5 to 22
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantI’m still not sure I am on the right track but you could place your door and manually set the sill height to what you want in relation to the wall base or storey level.
But if you want to automatically raise the height based on the door type then I would just add something like this to your 3D script …
if door_type = "type A" then ADDy 0.005 endif if door_type = "type B" then ADDy 0.007 endif if door_type = "type C" then ADDy 0.009 endif
Then when you place the door make sure you place it with the sill set to zero height above the wall base (or storey).
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantI am a little confused as to what you are trying to do.
WIDO_SILL_HEIGHT is a value calculated from the height of the door or window from the base of the wall it is placed in.
It is not a value you can set in the object script as it is not a parameter like height and width (A & B).
While you are scripting it may always return a value of zero as you object as yet does not belong to a wall.
It is not until you place an instance of the door in a wall that it can determine a value.You can force it (for testing) in your script by saying WIDO_SILL_HEIGHT = 0.100 in the master script but you will need to remove that line when saving the object for real as otherwise it will always use that value regardless of what height you place it.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantYou set it where you show your image – in the settings dialogue or info box.
WIDO_SILL_HEIGHT will read this value for use in your script – not set the value.Barry.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantMaybe this?
for n = 1 to (NSP) totalSum = totalSum + GET (1) next n print totalSum
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantStill doesn’t answer the question why the GS door worked though.
I am guessing the GS door knew to use the LibraryGlobals13 file for the 19 library and your doors would have been using the other one.
You will probably see two GDL options in your MVO dialogue.I know when you CALL a macro by name it actually compiles the GUID into the script (although we only see the name).
Once saved you can rename the call macro file in your operating system and the object will still find the correct macro even though it is calling the old name.So I am assuming the same is happening with the LIBRARYGLOBAL command – each was linked to the GUID for their respective macro file.
I may be wrong.Barry.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantThanks Dominika,
I thought that was going to be the answer but I was hoping there may have been something I wasn’t aware of.
Maybe it could be added to the wish-list of GDL improvements please?Barry.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantThank you Dominika.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitAugust 8, 2016 at 10:15 in reply to: Making 'Custom Settings' the default view in Object Settings Dialogue Box #2656Barry KellyParticipantIn the interface script of the object (in the main dialogue – not the separate script window) press the button at the top for “Set as Default”.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantHotspots are only visible when you select the object (label).
There is no way to make a hotspot visible without selecting that I know of.Textblock handles are completely different to hotspots and can’t be scripted.
They simply show the extents of the text box.Barry.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantUnfortunately you can only use autotext values.
GDL can’t actually read the values in autotext fields so therefore can not determine the text length.
It is a long standing problem.
We could do so much with autotext if only we could read the values.Follow this link …
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantA_ is used in the parameter script, which is GLOB_SCALE in old form.
Thanks for pointing this out – it is a good lesson.
I now must remember to search for the old form of GLOBALS when fixing up my library parts.
I might have missed this otherwise.Barry.
