Home › Forums › Problems and solutions in GDL › Informations from the environment › What is the proper replacement for GLOB_CONTEXT=1? › Reply To: What is the proper replacement for GLOB_CONTEXT=1?
Thanks for the reply Gergely but I really didn’t understand it.
I have never used the lp_xmlconverter.
It is not a case of updating the actual library part.
What I am trying to do is trap an actual object instance in a plan.
If it has a certain parameter then swap that.
I only want to check it once which is why the flag parameter gets reset.
If I don’t have the GLOB_CONTEXT <> 1 then the flag will reset in the script editor which I don’t want.
It needs to be off and only reset when I am not editing the script.
Not sure if that explains it any clearer.
Basically I need to trap (or exclude) when I am in the GDL editor.
How do I do that without GLOB_CONTEXT.
