Home › Forums › Problems and solutions in GDL › Informations from the environment › What is the proper replacement for GLOB_CONTEXT=1? › Reply To: What is the proper replacement for GLOB_CONTEXT=1?
October 23, 2015 at 07:40
#1807
Kristian,
I said there is no solution in GDL Editor, it is true. But for this problem, there is a much better, safer solution with using the lpxmlconverter. Setting the defaults for a complex library should be always done from source, professional GDL development can not be done without that, sorry. You simply do not have enough control on your objects without the source format and the checking/finalizing functions of the converter.
