Home › Forums › Problems and solutions in GDL › Parameter connections › Profile name in Master Script › Reply To: Profile name in Master Script
September 16, 2019 at 11:48
#18197
Hi Bruce,
You can not and should not reach any data of a profile from parameter script (including master, when it runs before parameter script). If you would be able to do so, that could cause inconsistent data in a plan file, as you can place an object using profiles, after that if you change anything in the profile that won’t be followed by a parameter script run, so your object could easily store outdated information or invalid, inconsistent data.
