Home › Forums › Problems and solutions in GDL › Informations from the environment › Compare parameter value to an Array in GDL › Reply To: Compare parameter value to an Array in GDL
October 18, 2019 at 11:35
#18277
Write a WHILE loop that compares the value to each value in the array, and terminates when found.
If you need to use it in many places with many arrays, write it as a macro.
