Home › Forums › Problems and solutions in GDL › Informations from the environment › Read Name of Project › Reply To: Read Name of Project
February 13, 2020 at 13:14
#18559
You can’t get the file path name and file path of the open project and then use it to make up the file path and name of a FULLPATH text doc from within the Parameter scripts. The parameter scripts are a crucial part as I need to then use the values from the text document lines to be able to do stuff with that data (parameter calculations etc).
